It is currently Mon Jun 15, 2026 4:22 pm
 Post subject: Carbon Hugger Update
PostPosted: Sun Nov 30, 2014 10:05 pm
Hi All, You may remember me asking if anyone knew if anyone made a carbon fiber rear hugger for a 750 Sport. Well after no luck it was suggested I tried wrapping it with the 3m Carbon look alike wrap. Although the actual wrap looked very realistic it failed to drape well around the curves so I gave up on that one. It was then suggested that I got it carbon dipped via Hydrographics. This has come out very well and has turned the pretty ugly large dull standard hugger into something a little more appealing...at least to me anyway!
So I thought I would attach a couple of pictures of it for any of you who may be interested.
I also may now have found a source for a real carbon one so I will advise details on here if that proves successful.
 Post subject: Re: Carbon Hugger Update
PostPosted: Tue Dec 02, 2014 5:42 am
Wow, that is amazing.
Not only that they would do a one off, but also that they got that to stick to polypropylene.
PostPosted: Thu Jan 08, 2015 1:55 pm
At my Sport there is a real-carbon rear hugger, but I have no clout where it comes from.
Cheers, Marcel
Marcel
Ducati 748S ('99)
Ducati 750sport ('88)
Husqvarna 450RR ('07)
PostPosted: Fri Jan 09, 2015 4:22 pm
can you post some pictures (specially from the left side)?
G:
PostPosted: Tue Jan 13, 2015 9:14 am
I also now have a real carbon Hugger. They are made by Diopa in Germany. basically it's a shorter version on the standard one above using the same locating holes as the 87-90 version sport. They list quite a few other things but this is the only one they do in Carbon. They are not quick at replying and struggle a bit with English! But quality was good, you have to drill the holes yourself but they are marked from the moulding process. Here's the link:-
http://www.diopa.com/shop/shop.html
PostPosted: Tue Jan 13, 2015 9:27 am
Carbon Hugger on Bike
PostPosted: Tue Jan 13, 2015 9:32 am
More Pics, with the original (now Hydro carbon coated) hugger next to it. The real carbon one doesn't cover the chain like the original.
PostPosted: Tue Jan 13, 2015 9:33 am
Another!
PostPosted: Tue Jan 13, 2015 7:08 pm
that looks like a standard SS hugger with the mounting tabs removed & shortened a bit
http://www.geelongcarboncraft.com.au/pr ... ugger.html
PostPosted: Tue Jan 13, 2015 7:13 pm
Similar but made for the sport. This is the listing:-
Vorheriger Artikel Liste 'Kotflügel vorn/hinten' Nächster Artikel
Kotflügel, hinten, "Superlight-90", ähnl.Orig., Duc 750/900, Bj.87-90, KF
C0156
Lieferzeit: ca. 10 Tage
Preis: 156.00 EUR
In den Warenkorb
