ducatipaso.org • View topic - clutch slave piston pin
It is currently Wed Oct 28, 2026 9:57 am
 Post subject: clutch slave piston pin
PostPosted: Wed Dec 10, 2014 2:28 pm
I took my piston pin or mushroom or whatever to a small machine shop yesterday to have a couple of them made for spares and he noticed a tiny hole all the way through it. I thought they were just lathe marks but no so is there a purpose for this hole? Everything in this area should be dry so I could not figure this out and all my other ones are bolted up to bikes so could not check. Pin only has 6k on it so I know it's not a mod of some kind.
By the way, where is everybody? It's been very quiet on the forum, just not seeing any new posts. Thanks Arch.
 Post subject: Re: clutch slave piston pin
PostPosted: Wed Dec 10, 2014 5:09 pm
Mine doesn`t have a hole through it but it doesn`t seem to be a bad idea. Either that or a tiny groove on the side. That would help fitting and removing the pin as you wouldn`t have to fight against trapped air when pushing it in or a vacuum when pulling it out.
The bearing is a sealed one so if over time dust entered the hole in the pin that would have no negative effect.
That it`s more silent than usual might be due to the time of the year.
PostPosted: Wed Dec 10, 2014 11:27 pm
Thanks G, that makes sense but mine was completely clogged and he had to push a piece of wire through it. Arch.
PostPosted: Fri Jan 23, 2015 9:11 pm
I'll be replacing my clutch bearing (again) in the coming months, so I'll take a closer look at the mushroom pin. I had ordered a replacement pin (from Stein-Dinse) but it was much smaller than the stocker, so I kept the stock piece.
And yeah, regarding activity, my Paso's been hibernating since October, when I lost the clutch. I expect to go through it sometime in March, and hopefully be back on 2 wheels shortly thereafter. It's been a balmy -20-0ÂșC around here lately ...
1988 Paso 750 #753965
1997 Monster 750
