ducatipaso.org • View topic - Loss of strokes
It is currently Mon Apr 27, 2026 5:16 pm
 Post subject: Loss of strokes
PostPosted: Sun Jan 15, 2006 9:40 am
Hi everybody,
my 907, when the motor is hot, sometime loss a stroke, at steady fast, and only about 3000 RPM.
Someone can tell me why :confused: ?
Ciao.
PostPosted: Sun Jan 15, 2006 2:11 pm
Is the battery in good shape? When you start the enigne, does it turn over easily or does the battery seem to struggle a little to get it to spin?
My 907 had the same problem, turned out the battery was on it's way out. New battery solved it.
-Craig
PostPosted: Mon Jan 16, 2006 5:26 pm
PostPosted: Mon Jan 16, 2006 5:40 pm
-Craig
PostPosted: Tue Jan 17, 2006 2:15 am
PostPosted: Wed Jan 18, 2006 11:11 pm
It's so!
I will clean all the contacs.
But you think that it can make loss the strokes?
PostPosted: Wed Jan 18, 2006 11:36 pm
:cool:
I think it is possible, but cleaning the contacts may help the starting, in any case.
PostPosted: Thu Jan 19, 2006 7:03 pm
Francesco,
If the battery contacts are really dirty / corroded they can reduce the available power to the point where it can just bring the solonoid in and barely turn the motor over. Make sure the contacts are clean and the terminals are tight.
Good luck.
Paul
PostPosted: Sat Jan 21, 2006 7:04 am
Really, only after 1 month that I've changed the battery his contacs seems corroded. It seems strange to me.
Thanx.
