It is currently Sat Oct 04, 2025 10:59 pm
Post new topic Reply to topic  [ 20 posts ]  Go to page Previous  1, 2
 Post subject: Re: fuel pump, rough running.
PostPosted: Mon Feb 23, 2015 11:33 pm
Sounds electrical to me, especially with the flaming backfire :thumbup:
PostPosted: Sun Jul 19, 2015 7:31 pm
Ok brothers, narrowed my cutting out to the ignition. No brainer probably, but, it seemed like that. Anyway, cleaned all contacts going to digiplex. Checked resistance to what I thought was the flywheel pickup, which was 770 ohms. One manual said 220 ohms and the other 150 maybe? The manual shows dual pickups, but, mine only has the single attached to the case cover. Is there a way to check air gap to that pickup? If so, it escapes me an my friend who is really the brains behind my troubleshooting. It's happens under hard acceleration mostly, it totally cuts out, then fires right back up, blowing a flame of unburned fuel out the pipes. The probably is keeping me from selling it and it's getting to the point of wondering if I need a new digiplex. Is it worth switching to Kokosun? Is one better than the other, and if so, what does the swap entail?
Thanks in advance. This bike will make a mechanic out of me yet.
 Post subject: Re: rough running (it's ignition!).
PostPosted: Thu Jul 23, 2015 1:05 pm
Sure your charging system is working ?
PostPosted: Mon Jul 27, 2015 12:52 pm
Checking it. Going to try the ignition relay mod. In the ignition switch, we found a voltage drop from 13V to 11V on one wire. That does not sound like a design feature.
PostPosted: Thu Jul 30, 2015 4:58 pm
looks like I got it going again strong. Put a relay to bypass the ignition switches. All hail to the forum!
