ducatipaso.org • View topic - 1990 900SS Small End
It is currently Wed Jun 17, 2026 10:54 pm
 Post subject: 1990 900SS Small End
PostPosted: Tue Sep 02, 2014 8:50 pm
After a year of very slow progress on parts I am almost there
Where I am stuck is who sells the small end bush/bearing (conrod to piston)
Before anybody asks why replace if not broken ... For the record most of the bearings needed replacement so I replaced all of the bearings & whilst I dont want to spend money for no reason I also want this to be a good mechanical runner i.e. I am keeping this machine long term ... so for the sake of say $40-$50 dooooollars why leave in there
The ones in there appear fine but as mentioned with bearings, seals, pistons ,etc why wouldnt I whilst a complete rebuild
Your expert advice would be appreciated on where to find would be great
 Post subject: Re: 1990 900SS Small End
PostPosted: Tue Sep 02, 2014 11:32 pm
I would be surprized if anyone sells those bushes separate , probly need a whole rod . I know what your saying about the TOTAL rebuild , a good nights sleep an all that but , if there is nothing wrong with the bushes you will gain NOTHING but debt by replacing them........if you even can . Im sure a good engine reconditioner could sort that for you , maybe modify a bush off something else .
Hamish
PostPosted: Wed Sep 03, 2014 12:15 am
Most likely comes with the rod but as Mctool states any decent engine overhauler should be able to fix you up if not a bearing shop
PostPosted: Wed Sep 03, 2014 12:49 am
Righto
All makes sense ... apologies for the newbie question
I have only been involved in 2 strokes in years gone by ...joke about that some other time but now that I am a big boy (old) this is the machine for me... which obviously a bit different (easier) than this exercise
Sorted
PostPosted: Wed Sep 03, 2014 1:33 am
PostPosted: Wed Sep 03, 2014 1:53 am
Top end bushes are usually pressed in, then reamed to size. Very important to ream them in the correct angle, then drill the oil holes, deburr, and add relief. All in all, not a simple task. Its not a do it yourself job, unless you have a proper machine shop in your garage. A new wrist pin will take up much of the wear anyway. Easy to find a new wrist pin, especially if you got a new set of pistons. Check the free play between a new wrist pin and the old bushing before you make the move. Changing out the top bushing just is not done too often, and finding a service to do it will be a bit of work in itself. E-bay rods from a low mileage motor will be much cheaper.
Phil
PostPosted: Tue Jan 20, 2015 7:58 pm
Update
The small end measured 1000 over max (not sure why so worn as not a high mileage machine which is why I bought it - that said no one knows full history unless owned from new ...maybe didn't keep up with oil maintenance) so whilst being balanced with new piston etc small end being replaced by engineer with the expertise and the gear - cost about extra $100 Nz dollars on balancing bla bla ... Both were necessary and worth it ... That was the last bearing in the whole machine that wasn't replaced anyway
The bush is apparently pretty standard as he made the call while I was there dropping off the crank ... Will update with details of the bush when I pickup for reference
PostPosted: Tue Jan 20, 2015 9:30 pm
sounds like a reasonable price to me :beer: not a complicated job but very time intensive to get it proper and of course you need the proper tools :mrgreen:
PostPosted: Mon Feb 23, 2015 7:02 pm
The small end is Nissan GA16/RB4107 19x22
Here's what they did (I made sure Staked to be sure)
REMOVE CON-RODS FROM CRANK.
REMOVE 2 X LITTLE END BUSHES FROM CON-RODS. MEASURE NEW BUSHES,
FREEZE FIT NEW BUSHES TO CON-RODS, DRILL OIL HOLES, HONE BUSHES
TO SUIT GUDGEON PINS. CLEAN, ALIGN CON-RODS, FIT BIG END
BEARINGS TO CON-RODS, CHECK CLEARANCE IN SPEC. & REMOVE BEARINGS.
BALANCE 2 X PISTONS, 2 X CON-RODS, SET UP BOB WEIGHTS, BALANCE
CRANK 52%, POLISH CRANK.
REMOVE OIL PLUGS FROM CRANK, ACID TANK CLEAN CRANK.
FINAL CLEAN CRANK, FIT OIL PLUGS, LOCKTITE STAKE OIL PLUGS, FIT
RODS TO CRANK.
PostPosted: Mon Feb 23, 2015 11:35 pm
:thumbup: :beer: :beer: :beer:
G you paying attention, that nissan info belongs in the FAQ :beer:
PostPosted: Tue Feb 24, 2015 4:34 pm
I am and everyone is free to post relevant infos in the FAQs. ;)
PostPosted: Sat Feb 28, 2015 6:09 pm
I put this in the FAQs now and then checked the '90 900SS parts catalogue. Other than the 750s parts catalogue the 900SS one lists the small end bush as #71110071A. I then googled the part number and found that it`s actually the same on many newer Ducs and no problem finding it.
http://www.2wheelpros.com/oem-parts/duc ... -part.html
2001 Ducati MH900E
2001 Ducati Monster I.E 900
2001 Ducati SportTouring ST2
2001 Ducati SuperSport Sport 900
2002 Ducati MH900E
2002 Ducati Monster IE 900
2002 Ducati SuperSport Sport 900
2002 Ducati SuperSport Standard 900
2003 Ducati Monster S 1000
2003 Ducati Multistrada DS 1000
2003 Ducati SportTouring ABS ST2
2003 Ducati SportTouring Standard ST2
2003 Ducati SuperSport SS 1000
2004 Ducati Monster 1000
2004 Ducati Multistrada DS 1000
2004 Ducati SuperSport 1000
2005 Ducati Monster Dark 1000
2005 Ducati Monster Dark 2 Dis 1000
2005 Ducati Monster Standard 1000
2005 Ducati Multistrada DS 1000
2005 Ducati Multistrada SDS 1000
2005 Ducati SuperSport DS 1000
2006 Ducati Monster 1000 S2R
2006 Ducati Multistrada DS 1000
2006 Ducati Multistrada SDS 1000
2006 Ducati SportClassic LE Paul Smart 1000
2006 Ducati SportClassic Standard 1000
2006 Ducati SuperSport DS 1000
2007 Ducati Monster 1000 S2R
2007 Ducati Multistrada S 1100
2007 Ducati Multistrada Standard 1100
2007 Ducati SportClassic Biposto 1000
2007 Ducati SportClassic GT 1000
2007 Ducati SportClassic S 1000
2008 Ducati Hypermotard S 1100
2008 Ducati Hypermotard Standard 1100
2008 Ducati Monster 1000 S2R
2008 Ducati Multistrada S 1100
2008 Ducati Multistrada Standard 1100
2008 Ducati SportClassic Biposto 1000
2008 Ducati SportClassic GT 1000
2008 Ducati SportClassic S 1000
2009 Ducati Hypermotard S 1100
2009 Ducati Hypermotard Standard 1100
2009 Ducati Monster S 1100
2009 Ducati Monster Standard 1100
2009 Ducati SportClassic GT 1000
2009 Ducati SportClassic GT Touring 1000
2009 Ducati SportClassic S 1000
2010 Ducati Monster S 1100
2010 Ducati SportClassic GT 1000
2011 Ducati Hypermotard EVO 1100
2011 Ducati Hypermotard EVOSP 1100
It's the also same on the 906, 907ie, 900SS, 900SSie, 900 Monster, 900ie Monster, Cagiva Elefant 900 etc etc
All 4 valve engines have different bushes as seem to have the smaller engines.
The gudgeon pin of the 900SS (19mm diameter) & the 750S have different part numbers so the small end bushes might be different.
