ducatipaso.org • View topic - threaded holes in my new headers?
It is currently Fri Feb 27, 2026 5:55 pm
 Post subject: threaded holes in my new headers?
PostPosted: Mon Mar 02, 2015 9:38 pm
So, I bought these new headers on the internet. they have these threaded holes in them (pictured above) which my original did not have.
My original had a hole in it, that's why I needed a new one :) but not threaded....
Any ideas?
 Post subject: Re: threaded holes in my new headers?
PostPosted: Mon Mar 02, 2015 10:26 pm
some headers had connections for a gas analyzer.
The thread should be a R1/8 (conical).
The old plugs were #000047113 (now 78010091A). Not sure if #78010071A is the same.
PostPosted: Tue Mar 03, 2015 5:32 pm
my header
PostPosted: Fri Mar 13, 2015 7:46 pm
thanks. conical thread huh... the things you learn...
PostPosted: Wed Mar 18, 2015 1:34 am
and thanks for the part number. The local dealer had them in stock. :D
PostPosted: Wed Mar 18, 2015 9:35 am
got the washers, too? Applying some anti-seize is recommended.
PostPosted: Sat Mar 28, 2015 10:11 am
PostPosted: Sat Mar 28, 2015 10:48 am
use a copper washer
PostPosted: Sat Apr 11, 2015 9:43 pm
PostPosted: Thu Apr 16, 2015 10:09 am
that should be ok, too. It should just be a washer that also can seal.
PostPosted: Thu Apr 16, 2015 10:01 pm
aluminum will work and are readily available
PostPosted: Mon Apr 27, 2015 2:44 am
PostPosted: Mon Apr 27, 2015 9:22 am
you want that bolt to sit airtight so you use a washer made out of a softer material than steel
PostPosted: Mon Apr 27, 2015 11:26 am
