ducatipaso.org • View topic - blue wire out of left side handle bar switch
It is currently Tue Oct 27, 2026 5:29 pm
 Post subject: blue wire out of left side handle bar switch
PostPosted: Thu Apr 09, 2015 9:51 pm
I can not identify this wire, was connected to frame tube just down from the re/rectifier mount. Is this a ground wire? It is blue not black, and connects into the left side handle bar switch. Diagram does not show it or I just can not see well enough at 68!
 Post subject: Re: blue wire out of left side handle bar switch
PostPosted: Fri Apr 10, 2015 8:20 am
It's the ground wire for the horn button.
PostPosted: Fri Apr 10, 2015 8:44 am
Derek, that would be the grey wire.
The diagram shows:
https://app.box.com/shared/3elasen7q7
There`s a blue/black going to the flasher relay and a blue which seems to be low beam.
PostPosted: Fri Apr 10, 2015 9:55 am
And if someone has fitted a two pole relay to the headlight that blue wire might be redundant :)
PostPosted: Fri Apr 10, 2015 1:14 pm
PostPosted: Fri Apr 10, 2015 5:06 pm
Thank you all, now I can push forward with confidence to the next issue, locating the correct 7mm in tank injection line.
PostPosted: Fri Apr 10, 2015 11:57 pm
Have a read of the topic viewtopic.php?t=6277
All you never needed to know about fuel line!
Cheers.
Nick.
