ducatipaso.org • View topic - Headlights over the years
It is currently Sat Jun 13, 2026 3:51 am
 Post subject: Headlights over the years
PostPosted: Mon Apr 27, 2015 11:31 am
I have an '87 paso and I annoyingly need a new headlight because the vehicle testing guy says my low beam is too hi and the adjuster screw is stripped.
on ebay there is one that looks like mine for 140 bucks and an 88 headlight for 56 bucks. anybody had experience with interchange?
 Post subject: Re: Headlights over the years
PostPosted: Mon Apr 27, 2015 11:40 am
I swapped the old CEV unit with a Koito.
It`s the same as on the Yamaha FZ750. No mods required.
PostPosted: Fri May 01, 2015 3:01 pm
How come the screw thread is stripped? You haven't touched it - must've been him.
PostPosted: Sat May 02, 2015 2:01 pm
I have a headlight assembly but its in the uk!
PostPosted: Sun May 03, 2015 1:20 am
Pablo , we must be able to fix a stripped thread , not like its holding up a bridge or lives depend on it ..... so maybe try bogging the hole with epoxy and then re-drill and tap it, or even try a helicoil . You gotta watch those E-bay headlights , if it dips the wrong way ( like from USA ) they can fail you on a W.O.F .Lemmie have a look at mine ( cant find it .... just moved house ) and I,ll see if I cant figure a cure , someone else was moaning :D about this not so long ago
Users browsing this forum: No registered users and 74 guests
