ducatipaso.org • View topic - Leaking Neutral switch
It is currently Fri Jun 19, 2026 1:59 pm
 Post subject: Leaking Neutral switch
PostPosted: Mon May 11, 2015 7:24 pm
My Neutral switch at the back of the engine is weeping oil. I have tried tightening but still leaking. Just wondering if fitting a new one will fix this and if anyone has any links to wear I might get a new one?
Many thanks
 Post subject: Re: Leaking Neutral switch
PostPosted: Tue May 12, 2015 8:46 am
Available from Steine Dinse -
It is the same as fitted to the SS and Monster models up to 1997, so should still be available from any Ducati dealer.
PostPosted: Tue May 12, 2015 9:14 am
where exactly does it leak? The neutral switch is installed with a washer/shim.
In case you plan to replace that note it exists in at least two different thicknesses. You`ll need the right one to make sure your switch works correctly.
PostPosted: Tue May 12, 2015 9:43 am
