ducatipaso.org • View topic - 906 cutting out
It is currently Sun Sep 28, 2025 1:56 pm
 Post subject: 906 cutting out
PostPosted: Fri May 15, 2015 6:08 pm
Hello, was messing around with my new to me 906 the other day and noticed that it starts and idles nicely and revs ok but it will shut off when I operate any switch on the left handlebar. I put a new battery in, not as bad but still same result. So do I have a short somewhere that kills power to the coils or ignition? Anyone ever had this problem before? I can't really get into it for a few days but was just wondering if someone else has had this problem. Thanks Arch.
 Post subject: Re: 906 cutting out
PostPosted: Fri May 15, 2015 11:39 pm
now thats almost funny
PostPosted: Sat May 16, 2015 3:57 am
?????. Arch
PostPosted: Sat May 16, 2015 5:30 am
Probly one of the most complained about Paso traits . Whats most likely happening is that you have a bad connection in the power supply ( to most of the bike ) and while idling its ok but switch on a light and the bad connection wont allow enough power to flow and the supply voltage drops and then the electronic ignition wont operate and the bike stops . There are numerous posts re the modification of Paso wiring ( basically fitting a relay ) which will improve things out of sight :)
PostPosted: Sat May 16, 2015 8:54 am
PostPosted: Sat May 16, 2015 2:38 pm
I had a similar problem. The bike used to cut out if I pressed the horn or operated the brakes. For me the worst one was when I indicated to go around a roundabout and it faltered every time the indicator flashed. I cleaned all the connectors up but got the biggest improvement by fitting relays, which is also described in this forum. Good luck.
PostPosted: Sat May 16, 2015 11:06 pm
Don't be daunted by the prospect of having to fiddle with wires . Ducati have made it more complicated than it needs to be , and , all the current used by the bike is switched thru the main ign switch. Basically you remove a couple of wires and fit a main relay ( standard on most sensible applications ). I have 4 relays ( possibly a bit of overkill ......which is underrated :D ) one eack for hi & low beam , one for the digiplex and coils and one for the main relay
PostPosted: Sun May 17, 2015 2:53 am
Thanks for the replies. I have read all thr FAQ's and have read all the posts from day one on all the models and know that our bikes have lots of electrical problems but at the time just either didn't know enough or don't remember reading about that specific problem. Now I've got someplace to start at least. I just started working on Duc''s less than two years ago and much different than the BMW's that I spent 30 years on. I don't really like working with electrics but it appears that I better start trying to figure it out! Thanks Arch.
