It is currently Thu Feb 26, 2026 3:59 am
[ 5 posts ] |
ducapaso
Post subject: Re: Abba stand, will it work on a Paso? Posted: Fri May 22, 2015 9:41 pm |
| paso grand pooh-bah |
Joined: Sun Aug 01, 2004 12:00 am Posts: 1097 Location: siena, italy
I'd like to see lot of pics about such bike. 750 engine is air cooled and 906 is water cooled. Switching means adding cooler, different oil cooling, different electrical and so on. After this we'll be able to tell you about periodical maintenance, timing belts, tyres, carbureteur tuning, shock, eletrical troubleshooting
_________________ have a nice ride, Nicola
Black "DUKE" 751582 ex...Red "smooth" 753349
| Top |
englishstiv
Post subject: Re: Abba stand, will it work on a Paso? Posted: Sat May 23, 2015 1:29 am |
Joined: Wed Apr 09, 2008 9:57 pm Posts: 1097 Location: Manchester, England.
If you take the two rear side panels off you should be able to locate the stand lugs into the bike frame. It will give you access to all the rear framework too for strapping down nice and tight. I would be careful strapping down over the bodywork generally as it can hairline crack quite easily if put under strain that way. Will be nice to see some pictures.
Did see a 906 that was dressed up with a 907 engine and injectors a while back with wheel and tire alterations also, always anything is feasible if you put your mind to it.
_________________ DUCATI 907ie STIMSON SCORCHER 3 WHEELER CZ 175 Sport.
| Top |
Guy
Post subject: Re: Abba stand, will it work on a Paso? Posted: Sat May 23, 2015 7:11 am |
Joined: Thu May 21, 2015 6:53 pm Posts: 3 Location: UK
Thanks for replies, I'm looking forward to seeing it to Could you tell me what size holes are in the frame, so I can make sure I have the right size lugs for the Abba stand.
| Top |
900streetfighter
Post subject: Re: Abba stand, will it work on a Paso? Posted: Sun May 24, 2015 9:07 am |
Joined: Wed Oct 27, 2010 5:52 pm Posts: 364 Location: Essex UK
I fabricate abba adapters from old sockets. Spark pplug sockets are a good start. Lead solder spigots into them and file down OD in pillar drill to fit stand adaptor.
| Top |
[ 5 posts ] |
Users browsing this forum: No registered users and 3 guests |
