ducatipaso.org • View topic - Steering head bearings
It is currently Sat Jun 13, 2026 4:00 am
 Post subject: Steering head bearings
PostPosted: Wed May 27, 2015 5:32 pm
I haven't dug into it yet, but I can tell I'm due for new steering head bearings. Just testing the waters before I start pulling things apart ... any gotchas I should keep in mind?
1988 Paso 750 #753965
1997 Monster 750
 Post subject: Re: Steering head bearings
PostPosted: Wed May 27, 2015 6:15 pm
The only tricky part is removing the inner race of the bottom steering bearing from the steering stem.
PostPosted: Wed May 27, 2015 6:19 pm
for everyone who has never done it
https://www.youtube.com/watch?v=_Ozfh93CvBs
https://www.youtube.com/watch?v=c-kVkqXiLdY
PostPosted: Thu May 28, 2015 6:48 pm
Certainly get tapered roller bearings instead of ball bearings. Last longer, feel better. Of course, good grease is important too. Plenty of it. Pretty hard to over grease a low motion bearing like the headset. Set it up with just tad of preload.
PostPosted: Thu May 28, 2015 10:20 pm
Unless you have some pretty trick bearing removing tools that lower inner bearing race is probly best ground ( dremel ) nearly right thru in 2 spots and then split with a cold chisel :)
PostPosted: Fri May 29, 2015 12:01 pm
PostPosted: Mon Jun 08, 2015 9:43 am
I normally cut an x pattern with a small angle grinder (a partly worn blade makes it easier as the diameter is smaller, but still be careful) and then knock out the triangular shaped bit with a cold chisel.
To get the lower bearing cup out of the headstock, I normally run a bead of weld around the cup surface after cleaning the grease off. When the weld cools it shrinks the cup and makes knocking it out very easy. A clean up with emery paper and a smear of copper grease makes getting it out the next time easier.
907IE
Paso 750
CB 900FD
KX 500
KTM 500 with Zabel 700 Engine
zx10
Mobylette Cady
Users browsing this forum: No registered users and 75 guests
