ducatipaso.org • View topic - Looking for some rotor measures...
It is currently Tue Jul 14, 2026 2:50 am
 Post subject: Looking for some rotor measures...
PostPosted: Thu May 28, 2015 10:18 pm
Evening Fellas, it's been a loooong looong time since I've posted. Hope everybody is doing well and enjoying their 2 wheeled adventures!
Quick question: According to my manual "new rotors" should measure 0.196-something and the wear limit is 0.177-something. What are do your rotors measure?
The brembos I put on my bike a while back have some pitting in them and I have a new/used set of OEM rotors I'd like to bolt up. The new/used ones measure 0.1556 and the ones on the bike measure 0.1554 and my old warped ones on the shelf measure 0.1554. I was thinkin "woa!" all of these are beyond the wear limit??! Thanks.
 Post subject: Re: Looking for some rotor measures...
PostPosted: Wed Jun 03, 2015 12:18 pm
Does anyone have a thickness measure on a set of new or very good condition OEM rotors? Thanks.
PostPosted: Wed Jun 03, 2015 1:35 pm
just have a look at the wsm ;)
PostPosted: Wed Jun 03, 2015 5:38 pm
Yup thanks, I have the manual as mentioned in my first post. Im looking for some actual measures.
PostPosted: Wed Jun 03, 2015 5:45 pm
new discs have 5mm and 4.5mm is minimum. You find that info also in every brake rotor manufacturers catalogs. The min. thickness is also stamped into the brake rotor. You won`t find any other info than that ;)
PostPosted: Wed Jun 03, 2015 5:50 pm
Appreciate the info; id still like to see what people measure on their OEM disks.
PostPosted: Sun Jun 07, 2015 8:29 am
PostPosted: Sun Jun 07, 2015 11:36 am
Thanks Nick!! I knew I wasnt crazy!
PostPosted: Mon Jun 08, 2015 10:05 am
strange that even the Brembo catalog says 5mm
https://app.box.com/shared/59pziy24rl
PostPosted: Tue Jun 09, 2015 12:51 am
Hi.
I spoke to Ian Gowanloch about the thicknesses of the 320mm rotors. He has a complete set on hand, and was positive they were between 3.5mm - 4mm. The one's he has are genuine Brembo disks. His opinion of the OEM (apparently they were Japanese Nissin, labelled as Brembo?) rotors was, umm, bad. He suggested if the bike still had the OEM rotors, throw them away are replace them with the new Brembo units quickly!
Found another couple of places with Brembo units for sale:
http://motowheels.com/i-7832676-brembo- ... 8-998.html
And from Metalgear (not Brembo originals, but heard good things about them):
http://metalgear.com.au/mgear-brake-dis ... 10986.html
It is interesting the Motowheels spec for the disk is a thickness of 5.5mm?
Cheers.
Nick.
Users browsing this forum: Google [Bot] and 17 guests
