ducatipaso.org • View topic - EFI rubber dampers
It is currently Wed May 06, 2026 4:00 pm
 Post subject: EFI rubber dampers
PostPosted: Wed Jun 03, 2015 6:36 pm
Any alternative source for the EFI rubber dampers?
 Post subject: Re: EFI rubber dampers
PostPosted: Wed Jun 03, 2015 9:57 pm
Hi Francesco.
Which one's? The airbox end or the inlet manifold? Or something else?
Cheers.
Nick.
PostPosted: Sun Jun 07, 2015 12:28 pm
The ones down to the ECU. The same are on the plate that supports the relays etc. on the left of the front fairing.
Mine are broken.
PostPosted: Sun Jun 07, 2015 2:50 pm
I got some from McMaster Carr. They are called Neoprene Vibration Damping Sandwich Mount, Male/Male, M6 Thread, 1/2" High, 1" Wide
I think in your area
or
should be able to supply what you need
PostPosted: Sun Jun 07, 2015 10:57 pm
As temporary fix cut a piece of fuel pipe to size and pass a nut and bolt through it, simple but it works and costs pennies.
PostPosted: Mon Jun 08, 2015 10:58 am
the silent blocks for the ECU are rather soft compared to standard ones
PostPosted: Fri Jun 12, 2015 5:06 am
Many thanks everybody :thumbup: :thumbup: :thumbup:
