ducatipaso.org • View topic - 90 900 Supersport Tidy-up
It is currently Thu Oct 02, 2025 11:59 am
Post new topic Reply to topic  [ 55 posts ]  Go to page Previous  1, 2, 3, 4  Next
 Post subject: Re: 90 900 Supersport Tidy-up
PostPosted: Tue Mar 31, 2015 8:14 am
With JE 11.5:1 high comps going in can anyone give me an idea to what I should retard the timing to start with (running 96 at worst)
Standard Marelli ignition (1989 to 1990) ... Very minor port (as had been messed with had it tidied up) .... Weber 116 .... Standard but new valves, guides
PostPosted: Tue Mar 31, 2015 9:53 am
11.5:1 is what the pistons say or what was measured after installing them?
2° is what you`d usually start with.
If the heads are off I`d take the chance to verify the correctness of the TDC marks. With the production tolerances they can be 1-2° off.
PostPosted: Wed Apr 01, 2015 5:09 am
Good point and thanks
PostPosted: Wed Apr 01, 2015 9:03 am
PostPosted: Wed Apr 01, 2015 9:39 am
1.931 (1989: 1.471, 1990: 460)
PostPosted: Wed Apr 01, 2015 9:53 am
PostPosted: Tue Jun 09, 2015 4:42 am
Next up the Forks
Sliders blasted & painted
Stanchions were straight but just started to bubble ... soooo in with some new ones to go with Bushes, seals, etc
Easy enough job
 Post subject: The Triple
PostPosted: Tue Jun 09, 2015 4:50 am
Same pretty simple ... new bearings in after packing
PostPosted: Tue Jun 09, 2015 4:56 am
Fairing Frame blasted & painted
Clear out the thread
Starting to put some of the work already done on to the frame ... starts to look like a machine
 Post subject: The Dash & the Headlight
PostPosted: Wed Jun 10, 2015 7:26 pm
She was smashed ... previous owner had run into the back of a truck with an overhanging load
What you see is what was under the black tape holding the gauges together & a replacement Headlight
Couldnt save any of that so in to search mode for replacement
On the Headlight I mixed & matched a replacement headlight with what I had
Some of the reflector has sh!t itself on the new HL which really p!sses me off as that wrecker has consistently sold wrecked bits at top dollar but consistently sent up crap - bought a rear light that was broken in the exact same spot as the one I needed to replace... the clip ons were good for nothing when I got ... & the airbox I bought is missing clips/bungs & the seat that sits in the carbs is deformed (I will take that up with them soon to be fair)
In with new bulb & T10 LED ... the right grease & back together
On the Dash sourced parts & in to the fairing frame
After reading various on LED's I am going to pop some T5's in the Dash Lights (have sourced coloured LEDs from China for about a coffee in cost)
Last edited by The Paua Poacher on Thu Jun 11, 2015 5:56 am, edited 1 time in total.
 Post subject: Dash Photos
PostPosted: Wed Jun 10, 2015 7:30 pm
mmmmmmmmmmm VEGLIA (hope I spelkled that right)
When installing I replaced all the rubber, bolts, etc, etc at same time (thats not the expensive bits)
 Post subject: Tank
PostPosted: Sun Jun 14, 2015 7:53 pm
While I wait for the Primary Drive to come back so the cases can come back together I started thinking about her clothes
As mentioned this has been down the road ... old owner hit overhanging truck load so the fairing frame took the brunt of the ding (damages were all consistent with that)
The front fairing on the machine I had was fibreglass so found a replacement ... still needs a major sand, glue & ground up paint
I haven't taken photo's of the fine stress cracks (there were only a couple) ... or the half ars$d repairs behind the fairings (all done before) but have shown the tank has been caught in time with only a bit of rust in one corner & not terminal (great)
I wont do this work as the tank needs a paint strip... repair weld the rear mount ...a little panelbeating ... reseal & full paint ... but is underway while I work on other bits
Question ... anyone have a fuel sender (would consider a pump as well) they are happy to move on? ... please PM
Need a Seat Cowl as well?
PostPosted: Sun Jun 14, 2015 10:36 pm
Fuel pump bits are all the same as the SS series from 1991 to about 2001 when they went to Fuel Injection.
Nice work so far.
PostPosted: Mon Jun 15, 2015 12:45 am
Phil
Thanks for the encouragement ... made a couple of errors in coatings (should have powder coated triple, sliders & clip-ons but that is an easy fix)
I thought that sensor would be different as the tank is a different shape & the Reserve is shitty as it is
Righto will start the hunt now as makes bloody easy
PostPosted: Tue Jun 16, 2015 12:45 am
Users browsing this forum: No registered users and 36 guests
