It is currently Wed Feb 25, 2026 4:41 pm
[ 9 posts ] |
| Author |
startline
Post subject: Hi all 900ss with 750 paso ignition help Posted: Thu Jun 18, 2015 5:24 pm |
Joined: Wed Jun 17, 2015 5:55 am Posts: 6 Location: UK
Right hoping for some confirmation on a digiplex 2 ignition fault, my 1990 bike has stopped sparking on the rear cylinder at 3700 rpm rev it up and rear cylinder cuts out, remove plug cap ground a new plug confirm s spark literally stops!, changed coils wiring from front to back and surprisingly it still stops sparking on the rear cylinder which indicates to me pickup or digiplex, pick up either works or not as far as I know and front is fineso assuming a new digitplex is required, front cylinder is fine on either coil and everything else passes as ok any thing I have missed? And I also assume a Paso 750 digiplex would work ok, air tube is also ok as is the digiplex earth HELP :-)
| Top |
Brutus
Post subject: Re: Hi all 900ss with 750 paso ignition help Posted: Thu Jun 18, 2015 6:50 pm |
Joined: Sun Jan 16, 2005 12:00 am Posts: 257 Location: The Netherlands
Hi, did you changed the coils also from vertical to horizontal..? Suppose you allready tried other spark plug cables etc to be sure..?
_________________ _________________ Better too late than too ugly..
| Top |
Post subject: Re: Hi all 900ss with 750 paso ignition help Posted: Thu Jun 18, 2015 8:02 pm |
| paso grand pooh-bah |
check the ignition switch
| Top |
Norman38
Post subject: Re: Hi all 900ss with 750 paso ignition help Posted: Fri Jun 19, 2015 9:26 am |
Joined: Tue Jun 16, 2015 9:31 am Posts: 5 Location: Germany
Has the pickup-line the greatest possible distance to the ignition cables?
| Top |
startline
Post subject: Re: Hi all 900ss with 750 paso ignition help Posted: Fri Jun 19, 2015 12:15 pm |
Yes 're coils, rewired them both, same fault, the pickup is working fine to the horizontal cylinder and both cylinders are fine to3700 rpm when the rear stops sparking, ignition switch must be ok because it's starting fine
| Top |
Derek
Post subject: Re: Hi all 900ss with 750 paso ignition help Posted: Sat Jun 20, 2015 9:31 am |
But the ignition switch is well known weak point and can develop resistance across the contacts dropping the volts on load. If the volts are down that could be a reason for the sparks stopping on the rear cylinder. The rear may be more sensitive to a reduced voltage. The cure for the ignition switch is to fit a relay to do the switching, triggered by the ignition switch.
| Top |
Post subject: Re: Hi all 900ss with 750 paso ignition help Posted: Sat Jun 20, 2015 12:14 pm |
| Top |
startline
Post subject: Re: Hi all 900ss with 750 paso ignition help Posted: Wed Jun 24, 2015 8:06 pm |
Paso ecu fitted and now perfect :-)
| Top |
Post subject: Re: Hi all 900ss with 750 paso ignition help Posted: Wed Jun 24, 2015 9:31 pm |
just got lucky, was a wiring issue most likely
| Top |
[ 9 posts ] |
Users browsing this forum: No registered users and 1 guest |
