ducatipaso.org • View topic - Clutch - Looking to replace - Advice please.
It is currently Sun Sep 28, 2025 5:05 am
Post new topic Reply to topic  [ 22 posts ]  Go to page Previous  1, 2
 Post subject: Re: Clutch - Looking to replace - Advice please.
PostPosted: Fri Jun 05, 2015 8:53 pm
the " premise" behind spaying a coating of white lithium grease onto you fiction disc is to "cure" the dryed material
I suppose if you wipe the disc clean afterwards not much harm would be done key on "not much"
sounds like a crackpot idea to me but many claim success
maybe someone should try soaking them in water and then let them air dry :banghead:
or just buy the suzie discs and ride on into the sunset
PostPosted: Sat Jun 06, 2015 7:26 pm
2004 ST4S
2001 ST4
1987 Paso 750
PostPosted: Mon Jun 08, 2015 10:20 am
PostPosted: Mon Jun 08, 2015 12:43 pm
2004 ST4S
2001 ST4
1987 Paso 750
PostPosted: Mon Jun 08, 2015 1:11 pm
I've never said anything like that. A dry clutch and a wet clutch are two completely different things. Spilling a quart of oil over a dry clutch also doesn`t make it a wet clutch. If you`re not sure do try.
The cars I know have a dry clutch btw. (except some with DCT)
PostPosted: Mon Jun 08, 2015 1:21 pm
2004 ST4S
2001 ST4
1987 Paso 750
PostPosted: Sat Jun 27, 2015 10:29 pm
Okay finally got to strip the clutch out today lots of rusty residue found and generally scruffy and mucky looking so after an hour or so tinkering and cleaning everything is back in place. Will see how things perform next week on my 2nd test ride after i have finished fitting the new belts.
So no new clutch yet and thank you all for your suggestions. :thumbup: :beer:
