| It is currently Fri Feb 27, 2026 6:59 am |
[ 15 posts ] |
| Author | Message | |||
| FasYankee |
Joined: Fri Jun 12, 2015 8:21 pm Posts: 28 Location: USA model: 906 Paso year: 1990 |
| Top | ||||
| jfiore |
Joined: Wed Jul 21, 2004 12:00 am Posts: 67 Location: Windsor, CT USA |
| Top | ||||
| Mc tool |
Joined: Wed Dec 05, 2007 12:35 am Posts: 1793 Location: Newzealand model: 906 Paso year: 1990 |
| Top | ||||||
| FasYankee |
| Top | ||||
| JWilliam |
Joined: Wed Oct 06, 2004 12:00 am Posts: 327 Location: Nottingham, UK model: 906 Paso year: 1989 |
| Top | |||||
| FasYankee |
| Top | ||||
| paso750 |
Joined: Sun Jul 18, 2004 12:00 am Posts: 5494 Location: southern Germany model: 750 Paso year: 1987 |
| Top | ||||||||
| FasYankee |
| Top | ||||
| paso750 |
| Top | ||||||
| FasYankee |
| Top | ||||
| ducinthebay |
Joined: Sat Sep 03, 2005 12:00 am Posts: 1323 Location: SF Bay Area model: 750 Sport year: 1990 |
| Top | ||||||
| JWilliam |
| Top | |||||
| Mc tool |
| Top | ||||||
| ducinthebay |
| Top | ||||||
| Mc tool |
| Top | ||||||
[ 15 posts ] |
Users browsing this forum: No registered users and 4 guests |
| You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot post attachments in this forum |
. I think its a maintenance thing , I spose one could argue that the power pulses of a V twin MAY cause a shock loading that could loosen the bolts but , like I said , it aint peculiar to Paso's , and singles would have to be worse. My sprocket is held on with cap screws ( hi Tensile ) and nuts ( not lock nuts ) and Loctite . The whole idea is that the sprocket is clamped to the carrier by the mounting bolts , and as such shouldered bolts would only be of benefit once the sprocket has come loose and the bolts are in shear, having said that , I do agree with jfiore that shouldered bolts should be used. When mounting sprocket make sure the mating surfaces of both the sprocket and the carrier are clean and smooth, these are the surfaces that clamp together and it stands to reason that if they are not smooth and clean ( like a layer of chain lube and grit ) then they are hardly likely to clamp solidly , bit like putting crap on your brake discs and then expecting a steely grip........ aint gunna happen. It all comes down to basic maintenance/ cleaning. When you clean a bike you ( eventually, for some )get to know the bike and anything out of the ordinary gets to be a bit obvious ( I have a friend that apparently believes basic maintenance should be done in the middle of @#%king nowhere on the side of the road , and I don't ride with him anymore coz Im sick of waiting round ( in the middle of @#%king nowhere)( on the side of the road ) while he bolts back on whatever bit has just fallen off ).The cush drive does have a bit of movement back and forth around the axle , if its wiggly sideways too then a inspection of the sprocket carrier bearings is a must.
) and it aint because of any rigours maintenance schedule ......or gallons of Loctite ( it will probly happen to every bike I own now
)maybe I just been lucky ........I have chucked a chain thru crankcases 3 times tho
beats me
