ducatipaso.org • View topic - Clutch Issue
It is currently Sat Feb 28, 2026 6:37 am
 Post subject: Clutch Issue
PostPosted: Fri Aug 07, 2015 5:14 pm
Hello. I have a 1987 750 Paso that I bought a few months ago. It only has 3,300 miles and ran and shifted fine but had a leak in the clutch master cylinder. I replaced that but the clutch wouldn't engage so my mechanic told me something was wrong with the slave cylinder and that the previous owner had put automatic transmission fluid in the clutch resevoir. I got a used slave cylinder out of Eastern Europe and a new slave cylinder seal. The Ducati shop put it all back together but still could not get any clutch pressure and they don't know why. So the bike sits and summer is moving on. Does anyone know what I should do???
Thank you.
 Post subject: Re: Clutch Issue
PostPosted: Fri Aug 07, 2015 6:20 pm
Try bleeding from master cylinder at the banjo bolt/hose connection. I replaced my banjo bolts for nipple style.
PostPosted: Fri Aug 07, 2015 10:17 pm
PostPosted: Sat Aug 08, 2015 10:50 am
2004 ST4S
2001 ST4
1987 Paso 750
PostPosted: Sat Aug 08, 2015 11:11 pm
