ducatipaso.org • View topic - I got a regulator but......
It is currently Sat Jun 20, 2026 10:14 am
 Post subject: I got a regulator but......
PostPosted: Tue Sep 29, 2015 5:25 pm
..I need to be sure how to wire it so the smoke stays in!
I have searched the board but I have not found a definitive answer on what to connect where.
I have a 5 wire replacement for the 6 wire stock RR. Battery, ground and lamp are no problem but what do I do with the 2 yellows and 1 red of the alternator to connect them to the 2 yellows of the new RR?
Please be gentle, I just don't want to torch anything!
Thanks, Hunter
Just smile and nod..........
 Post subject: Re: I got a regulator but......
PostPosted: Tue Sep 29, 2015 5:48 pm
PostPosted: Wed Sep 30, 2015 12:41 am
Thank you Higgy.
One more question: On the original it seems that the red wire to the alternator had 12v on it from the regulator. Do I need to make a 12v connection to that wire externally for this to work now?
Hunter
PostPosted: Wed Sep 30, 2015 11:34 am
NOTE:
For models with 2 x Yellow and 1 x Red generator wires, please use type RR51, with both yellow
generator wires connected together as 1 phase wire to the RR51, and the red generator wire as the
second phase wire to the RR51.
PostPosted: Thu Oct 01, 2015 12:59 am
So here's what I have:
When I hook the 2 yellow from the alt together to one yellow of the RR and the red from the alt to the other yellow I get no charge. When I hook the 2 yellow from the alt to the 2 yellow on the RR I do get a charge and about 50 VAC on the yellows at 3k rpm. But will it live in the long run with the red to the alt disconnected?
Hunter
PostPosted: Thu Oct 01, 2015 10:58 am
what regulator are you using ? make and model
PostPosted: Thu Oct 01, 2015 3:55 pm
Higgy,
It is this one:
http://www.ebay.com/itm/261367017203?_t ... EBIDX%3AIT
The instructions you listed are identical to those supplied with mine. When I hook it up as a 2 wire it works, as a 3 wire it does not.
This is where Mr Spock raises his eyebrow and says "Fascinating".
Any ideas?
I suppose to be safe I should pull the engine cover off and have a look. I just put all the fairing back on!! :banghead:
Hunter
PostPosted: Thu Oct 01, 2015 4:14 pm
looks like the two yellow should be to the stator,should not matter which goes to which
and the red should go to the battery
unless of course you have the 3 wire stator :banghead:
PostPosted: Thu Oct 01, 2015 5:37 pm
PostPosted: Thu Oct 01, 2015 6:57 pm
