ducatipaso.org • View topic - Spark plug recommendations for 750 Paso
It is currently Sat May 09, 2026 12:20 pm
 Post subject: Spark plug recommendations for 750 Paso
PostPosted: Mon Oct 26, 2015 8:12 pm
Can anyone give some help in choosing the right spark plugs for my 750Paso. Thank you.
 Post subject: Re: Spark plug recommendations for 750 Paso
PostPosted: Mon Oct 26, 2015 8:49 pm
Champion RA6HC
PostPosted: Tue Oct 27, 2015 12:15 am
Thanks, I know that is what the owners manual says, But I have never had good luck with Champion
Plugs. Have they worked well for you? Is there another better plug? I see the Bosch silver sport #7701 or
Xr4cs listed. Would that be a better choice? Thanks for your help.
PostPosted: Tue Oct 27, 2015 12:56 am
+1 Champion RA6HC
PostPosted: Tue Oct 27, 2015 9:24 am
I've always has good results with NGK plugs. The DCPR8E is recommended for the 750 Paso.
PostPosted: Tue Oct 27, 2015 10:52 am
PostPosted: Tue Oct 27, 2015 6:13 pm
while you can go with iridium, platinum whatever plugs you`ll notice that the most simple ones work best.
PostPosted: Thu Oct 29, 2015 2:42 am
Thanks for the help, one & all!
PostPosted: Thu Oct 29, 2015 4:50 am
The champions run best in the Sport for me. And they are cheap. Less than $2 at the local auto parts store. I never had a good view of Champion plugs in the past, but they work better than any $10 plug I've tried.
PostPosted: Thu Oct 29, 2015 4:51 am
Thanks again!
PostPosted: Thu Oct 29, 2015 4:53 am
Just bought them at Autozone for $1.95 each! I hope they work...
PostPosted: Sat Oct 31, 2015 2:13 am
if you would do a little searching here on plugs you would find a lot of Paso owners before they had a Paso wouldn't put champions in there worst enemies lawn mower.Then they bought a Paso,or 2 or 3 and we all use Champions now
NGK iridiums work but the simple fact is champions will last longer and for a lot cheaper
PostPosted: Sat Oct 31, 2015 5:18 am
Thanks for all the info! Such a Cheap little plug on such a Great motorcycle. I am glad that they work!
