ducatipaso.org • View topic - Fuel tank leak
It is currently Tue Jul 14, 2026 5:01 am
 Post subject: Fuel tank leak
PostPosted: Mon Nov 09, 2015 1:35 pm
We just noticed yesterday a small fuel leak apparently from the "A" outlet on the tank. This is just when the pump is activated. We pulled the tank off and cleaned around the outlet tube but nothing apparent. So it seems since its only leaking with pump is activated with pressure there could be a hairline crack. Anyone have this happen or suggestions.
I just got the 907 from a friend that was selling from his collection to enter retirement soon.
 Post subject: Re: Fuel tank leak
PostPosted: Mon Nov 09, 2015 6:03 pm
Is it possible that the leak is not from the outlet but from between the hose and the outlet?
J
PostPosted: Mon Nov 09, 2015 9:44 pm
we pulled the hose off stuck a finger over the outlet and gas started running down my finger. Not to say it wasn't from somewhere and not the outlet. Tomorrow I will retry the test when I can let the tank up and with proper light.
PostPosted: Tue Nov 10, 2015 9:48 am
If you have someone to help you could try to pressurize the tank.
Don`t know if it`ll work but you could cut short pieces of fuel line, drive a bolt into them and put them on every hose connection. Remove the gas cap and with a little bit of gas in the tank use a compressor to build up some pressure. You`ll need to cover the opening with a damp towel or similar. While one does that the other can check if there are any bubbles or fuel leaks visible.
PostPosted: Tue Nov 10, 2015 1:48 pm
keep the pressure very low or you risk the tank expanding. Under 5psi.
Personally I'd stick to a hand pump.
PostPosted: Tue Nov 10, 2015 2:01 pm
there won`t be any problem as you can`t seal the tank well enough to create a significant pressure in it.
Specially not if you`re holding the the nozzle of the compressor inside while trying to cover the rest with something.
You won`t be able to create any pressure with a hand pump unless everything is so well sealed that no pressure escapes.
PostPosted: Wed Nov 11, 2015 12:05 am
Well JJw member if you meant the hose on the outlet was where the leak is...you win a beer or something.
I actually observed the previous tests and didnt do hands on! But today as I was fitting the hose on I realized it wasn't going on very tight and maybe my friend had not tightened the clamp tight enough. So I put two clamps on and tightened them and WALAH no leaks. So I think the fuel lines are a bit oversize for what is needed I did cut an inch off before putting them back on but not that tight a fit on the outlet. So again I was looking for the worse and ignored the obvious.
Thanks to all.
PostPosted: Wed Nov 11, 2015 6:27 pm
Hey, thats good news. Good feeling when you fear the worst and it turns out to be something simple. Had that with the "coolant in oil scare" Now I am hoping that the front of my tank is not leaking......... :wacko:
PostPosted: Mon Nov 16, 2015 1:13 pm
100 mile ride yesterday and all is well!!! New battery so instant startup!!
PostPosted: Mon Nov 16, 2015 5:08 pm
Good to hear.
I am trying to decide if i should try a coating inside the tank or grind off the support and reweld. I noticed that the weight of the fairing is supported by the tank and all of the forward weight is hanging on that one support button. I suspect the tank flexes a bit under load causing the leak. Internal coating might crack unless it stays fexible? Has anyone had success repairing this leak at the front mounting?
Cheers J
PostPosted: Mon Nov 16, 2015 8:42 pm
PostPosted: Tue Nov 17, 2015 12:47 am
should have ducked Hamish.............
You all healed up now ?
PostPosted: Tue Nov 17, 2015 12:50 am
The 907 has a support plate welded in place. I have often thought of doing the same to the 906 and the 750. Tanks can be welded but must be cleaned with soap and water thoroughly and air dried then filled with argon to prevent explosive reactions.
Not a big deal for some welders, others won't touch it
PostPosted: Tue Nov 17, 2015 5:55 am
I have fitted such a support plate to my 906 ( piece of cake ), pix if you want . Mine was leaking via a crack that was close around the base of that support tube thing .
:lol: Higgy , I saw that image too , agonised for , oh about 2 seconds which one to post :D
PostPosted: Wed Nov 18, 2015 6:06 am
Yes please, pictures of the front mounting boss repair would be great. (the tank that is, not yours)
Cheers J
