ducatipaso.org • View topic - Carb issues
It is currently Tue Jun 16, 2026 2:44 am
 Post subject: Carb issues
PostPosted: Fri Sep 25, 2015 12:20 am
I was reading the CV carb swap but it got off topic.....my question is can you use a set of 750 or 900 SS carbs on the Paso? I still have the stock carb on the bike and it runs like shit! I cleaned it once and ran good and now running like crap again. I would like to find a set of Super Sport cards and toss them on there.....any thoughts?
 Post subject: Re: Carb issues
PostPosted: Fri Sep 25, 2015 6:56 am
It was born with a weber ,and it can be improved upon but if you really want to "up" carb your motor , font duck about, go for the 39 FCR kit :)
PostPosted: Fri Sep 25, 2015 2:03 pm
I just want to get it running decent and would rather put a set of 39's on my 900ss....so sticking with the paso, can I use the CV's from my 1996 900ss on it??
PostPosted: Fri Sep 25, 2015 4:56 pm
be sure to check the voltage at the coils and CDI units and the wiring mod.
Regarding the Mikunis check the FAQs.
PostPosted: Sat Sep 26, 2015 7:52 am
PostPosted: Sun Sep 27, 2015 5:07 pm
Can I suggest to have a look to my suggestions about balancing your weber?
PostPosted: Mon Nov 23, 2015 2:47 pm
little suggestion from one who has been riding with the weber for the last 28 years.
I already posted this somewhere else in the forum anyway, anyway, may be it can help
Air filter box removed and replaced with a homemade one using a Fiat abarth metallic air filter
fuel screws open by 720° (small adjustment then but it is a good starting point).
Then i connected the 2 holes in both side of carb base together with an alluminium tube, (you can use a fuel hose)
Apart from the advantage of smooth running, you can regulate carb settings only by removing a side fairing.
No need to remove fuel tank.
