ducatipaso.org • View topic - 906 brakes
It is currently Tue Sep 30, 2025 7:38 am
 Post subject: 906 brakes
PostPosted: Mon Feb 06, 2006 1:27 pm
Is it possible to mount a 748 brake fluid pump on a 906 (original seals are broken, and ik can buy a new 748-one)
thanks! Marcel
Blue Paso 906 1990
PostPosted: Mon Feb 06, 2006 4:27 pm
Surely U can, but if U have normal old style 2 piston Brembos, like also 750 Paso have, it can be, that "feeling" in brake lever changes, cause that 478 pump is designed to 4 piston calipers and have bigger piston diameter. I think best to You is to try find also black, or golden 4-piston Brembos to Your 906 and add them with adapters to M1R fork. I make such modification to my 750 Paso with braided steel brake lines and now they are MUCH better ones, than those old 2 piston black ones. Especially, when 906 is about 18 kg heavier, than 750 Paso, so If i would own 906, that modification is one of first to make to her to get better driveability :thumbup:
PostPosted: Mon Feb 06, 2006 7:28 pm
Thanks! I will look for the 4 piston Brembo's!
keep you posted!
Blue Paso 906 1990
PostPosted: Mon Feb 06, 2006 7:40 pm
I added black ones from 907IE 1991 modell and then need also that PS 16 master cylinder from 907(or from 748 with plastic liquid tank), cause normal 750/906 master cylinder is that smaler one PS 13, what You CANT use with 4-piston calipers. :thumbup:
Users browsing this forum: No registered users and 52 guests
