| It is currently Thu Oct 29, 2026 11:45 pm |
[ 10 posts ] |
| Author | Message | |||
| pate |
Joined: Mon Nov 09, 2015 12:27 pm Posts: 3 Location: Scotland model: intending to buy a Paso/Sport year: 1985 |
| Top | ||||
| Mc tool |
Joined: Wed Dec 05, 2007 12:35 am Posts: 1793 Location: Newzealand model: 906 Paso year: 1990 |
| Top | ||||||
| nickta |
Joined: Tue Jul 24, 2012 8:54 am Posts: 287 Location: Cairns, Queensland, Australia model: 907 I.E. year: 1992 |
| Top | ||||
| Mc tool |
| Top | ||||||
| paso750 |
Joined: Sun Jul 18, 2004 12:00 am Posts: 5494 Location: southern Germany model: 750 Paso year: 1987 |
| Top | ||||||
| Derek |
Joined: Thu Nov 03, 2011 10:13 am Posts: 769 Location: Scotland model: 907 I.E. year: 1994 |
| Top | ||||||
| paso750 |
| Top | ||||||||
| Derek |
| Top | ||||||
| pate |
| Top | ||||
| Derek |
| Top | ||||||
[ 10 posts ] |
Users browsing this forum: No registered users and 3 guests |
| You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot post attachments in this forum |
There is a FAQ section that will probly have the type of oil req and the amount . The only tip I can add is that both forks are different internally , one is compression dampening ( the Right ) and the other is rebound ( left ) so don't get the bits mixed up ( do 1 at a time ) and be carful with the rebound adjuster as sometimes the adjuster can gum up and it aint hard to strip the guts out of the knob ( and they are rare as haggis shit )if you try to force it to turn . Forks are 43.5mm so you need the right seal and when removing the seal don't use a narrow lever ( like a screwdriver ) as the top of the outer tube can be damaged as you apply pressure to the lever , use something like a tire lever and put a bit of packing ( bit of folded card ) between it and the top of the fork tube . When you have done all that you can them come back here to find out how to fix the electrical faults
the standard Webber carb is there as well, but manifold stubs have been cut. Thanks again folks, anyone out there anywhere near the Scottish Borders?
