ducatipaso.org • View topic - starting problems 906
It is currently Mon Sep 29, 2025 6:59 pm
 Post subject: starting problems 906
PostPosted: Mon Feb 06, 2006 1:07 pm
Since short I have starting problems on my 92 Paso 906.
Some help from you guys would be most welcome.
Sorry at first for my English, I'm Belgian.
I tried starting the bike with the choke open, and without gassing, but he wouldn't pick up. After several try's I think now the bike is overfuellled. Battery is ok, spark plugs ok, starter engine ok,...
Help me restart my darling please, because I want to serve my Honda Blackbird-loving brother a lesson he won't forget.
Thanks in advance.
Pasofreak Belgium.
PostPosted: Mon Feb 06, 2006 1:35 pm
Hi, look at the site of Bauke http://www.geocities.com/MotorCity/Factory/4030/ there's a wiring modification, it's a day work, but my starting problems are solved!
regards Marcel (from Holland)
Blue Paso 906 1990
PostPosted: Mon Feb 06, 2006 1:37 pm
Sorry, this is the right URL http://www.geocities.com/davidhooau/pas ... _mods.html
Blue Paso 906 1990
PostPosted: Mon Feb 06, 2006 3:26 pm
Thanks, but I don't think the problem is bad wiring. As I said the carbs are overfueled. Otherwise my bike runs perfect. Thanks anyway.
PostPosted: Mon Feb 06, 2006 3:27 pm
PostPosted: Mon Feb 06, 2006 4:35 pm
If its "overfueled", You need to take spark plugs away and run with starter engine enough long time, that there is not anymore fuel between pistons and heads !!!! AND dry plugs! My 750 had made such some times when it was fitted with Weber and only way is to dry it!!! ...or did i understand wrongly that "overfueling" ??? :confused:
PostPosted: Tue Feb 07, 2006 2:45 pm
ok super ! I'll try and let you know. You did understand my english well enough. This is what i meant with overfueled.
PostPosted: Wed Feb 08, 2006 8:38 am
Problem solved. I have a great solution for problems like this : Start Pilote. It is an aerosol available in most hardware stores. You need to spray it into the airbox (mine is K&N) and start with choke without gassing. A big bang and the engine runs.
Thanks for trying to help me out guys.
Pasofreak.
PostPosted: Wed Feb 08, 2006 4:48 pm
Hi everybody,
The 906 are famous for this.
Sometimes my old 906 made some "Big-bang" so loud that the rubble of my garage fall down!!!
Also in the test of "Motociclismo" (Italian bike's newspaper) they said it as peculiarity of these bike.
Ciao.
PostPosted: Thu Feb 09, 2006 8:01 pm
My 750 Paso with Weber did also that same, when engine stopped just, when it was hot. Maybe some fuel went to hot exhaust system and there was very loudly big BANG coming from exhaust pipes! It was very funny way to scared peopple, who didnt know that!!! :funny: :funny: :funny: Best experince was in north Italy, when i was coming down from Cortina to Tarvisio and there was many small villages with stone buildings in curvey roads. When i came to down to villages, Paso started to bang very ludly between those stone houses and there was many Italian women(and surely many men) showing, that they like very much that "Italian lifestyle" with Ducati :D :D :D She was VERY loudly there! :thumbup:
PostPosted: Sat Feb 11, 2006 4:33 pm
PostPosted: Sat Feb 11, 2006 4:42 pm
PostPosted: Sat Feb 18, 2006 2:35 pm
Users browsing this forum: No registered users and 33 guests
