| It is currently Wed Oct 28, 2026 4:30 am |
[ 11 posts ] |
| Author | Message | ||||
| Bonza |
Joined: Sun Feb 13, 2011 9:51 pm Posts: 16 Location: Canada model: 907 I.E. year: 1991 |
| Top | |||||
| higgy |
Joined: Tue Jul 29, 2008 9:50 pm Posts: 3259 Location: Hilltown,Pennsylvania model: 906 Paso year: 1990 |
| Top | ||||||
| Mc tool |
Joined: Wed Dec 05, 2007 12:35 am Posts: 1793 Location: Newzealand model: 906 Paso year: 1990 |
| Top | ||||||
| Derek |
Joined: Thu Nov 03, 2011 10:13 am Posts: 769 Location: Scotland model: 907 I.E. year: 1994 |
| Top | ||||||
| paso750 |
Joined: Sun Jul 18, 2004 12:00 am Posts: 5494 Location: southern Germany model: 750 Paso year: 1987 |
| Top | ||||||
| Bonza |
| Top | |||||
| Mc tool |
| Top | ||||||
| Bonza |
| Top | |||||
| Mc tool |
| Top | ||||||
| Tamburinifan |
Joined: Thu Jun 21, 2007 12:00 am Posts: 1501 Location: Gothenburg, SWEDEN model: 907 I.E. year: 1991 |
| Top | |||||
| paso750 |
| Top | ||||||
[ 11 posts ] |
Users browsing this forum: No registered users and 27 guests |
| You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot post attachments in this forum |
). There is supposed to be a spacer , a bearing and a washer on that camshaft before the pulley goes on , and from memory the pulley is not that tight a fit on the camshaft ( don't tell Gilbert
) , like you can pull it off with your hand. The cam on the front cylinder also has the gear to drive the tacho and any spacers may be different sizes to allow for this , so make sure you have them assembled correctly , also I think ( not sure ) that there is a circlip ( just a piece of steel wire formed into a circle ... not the type with holes in the ends for circlip pliers ) that fits into a groove on the cam shaft which would stop the bearing , spacer , tacho gear and washer from sliding on to far , there is one on the cam drive shaft at the base of the Vee behind both drive pulleys . Sorry if Ive got this wrong but I just cant figure out how the shaft diameter and the pulley bore could wear so Im thinking by being sloppy you are referring to excessive end float. If there was enough movement between the pulley and shaft to cause significant wear Im pretty sure it would flog out the key way and shear the key way before wearing the shaft / bore to the point that it was unserviceable.
