ducatipaso.org • View topic - Dashboard Died
It is currently Wed Jul 15, 2026 2:03 am
 Post subject: Dashboard Died
PostPosted: Wed Mar 02, 2016 10:05 am
Hi all,
I Was riding today after the bike had a year long hibernation and the dash died on me. Obviously the mechanical MPH and RPM still work. I can start the bike just fine. No gas level, water temp, turn signals, clock (which is still good) or information lights (kickstand, neutral, etc.). Just want to check if this has happened to anybody else or is a common issue. I did a search the forum but didn't find anything. I looked at the work shop manual and didn't find anything.
a couple questions:
Is this a single fuse that does the dashboard and turn signals?
If so, which one(s) fuse runs the dash (F2-F5?)
Are any of the connections known to fail?
I will start checking all the connections in the morning. I did find in my search that there are three connectors that go to front of the bike - any confirmation here would be very helpful...
I have to do a major in the next couple months on my own for the first time - doesn't look too complicated as I am used to picky, complex Italian machines.
Any direction is certainly appreciated!
 Post subject: Re: Dashboard Died
PostPosted: Wed Mar 02, 2016 6:48 pm
With all them things crapping out at once Id be looking at the earth wire/connection for the dash ( something that is common to all failed things ) usually bolted to the frame either side of the steering head
PostPosted: Thu Mar 03, 2016 9:32 am
The only thing I can see that will fit all these symptoms is the 4 pin connector has popped out of the back of the dash.
PostPosted: Thu Mar 03, 2016 12:08 pm
PostPosted: Thu Mar 03, 2016 7:06 pm
You guys are funny. I will report back to let you know who wins!!!
PostPosted: Fri Mar 04, 2016 9:18 am
PostPosted: Fri Mar 04, 2016 11:02 am
PostPosted: Mon Mar 07, 2016 3:02 pm
there's another option - if the top mount for the dash fails the dash flops back and can break the PCB track where it rubs against whats left of the mount.
PostPosted: Tue Mar 22, 2016 12:24 pm
Well, the winner on problem finding is!?
Proud owner of a;
- Ducati 907 ie 1992 in red
PostPosted: Fri Apr 15, 2016 7:55 am
PostPosted: Fri Apr 15, 2016 8:09 am
if it was a blown one, why did it? ;)
PostPosted: Fri Apr 15, 2016 4:22 pm
If the battery is not fully charged this causes the voltage to drop which in turn increases the current ( amps) and this can blow the fuse! Always have a good battery on a bike as low or unstable voltage can damage electronics ie the ignition or fuel injection system !
The Benelliman
1992 907ie
1981 Benelli 900 Sei
1989 Benelli 900 Sei
1976 Benelli 125 Enduro
1981 Benelli 250 2c
1976 Benelli 250 Quattro
PostPosted: Sat Apr 16, 2016 8:46 am
PostPosted: Sat Apr 16, 2016 10:12 am
Hi Derek you are correct my mistake! But electronics are still effected by increased or decreased voltage!
The Benelliman
1992 907ie
1981 Benelli 250 2c
PostPosted: Sat Apr 16, 2016 10:09 pm
Excuse me Derek, not everything is ohmic and under the correct conditions non ohmic devices can include the battery
Users browsing this forum: No registered users and 28 guests
