ducatipaso.org • View topic - DucatiDiag,JPDiag and GuzziDiag
It is currently Mon Mar 02, 2026 11:36 pm
Post new topic Reply to topic  [ 53 posts ]  Go to page Previous  1, 2, 3, 4  Next
 Post subject: Re: DucatiDiag,JPDiag and GuzziDiag
PostPosted: Mon Mar 28, 2016 9:08 am
just a note
ALL content from Ulitmap/FIM is still online at the internet WAY BACK MACHINE :beer: :beer:
go here
then copy and paste this url in the search window
pick a year and then any blue highlighted link and everything online at that date is availible :beer: :beer: :beer:
PostPosted: Thu Apr 21, 2016 12:09 pm
progress report
Have settled on the Arduino Mega 2560 for the ECU
Simple, $40 USD Small footprint in a box it measures 62mm wide x 112mm depth x 35mm (39mm) height
prototyping has started and BTW it looks fully compatible with the MyECU products :thumbup: :beer: :beer:
PostPosted: Thu Apr 21, 2016 2:38 pm
Interesting project.
You could buy a P8 (90`s Laverda is cheap), buy chips from China/ebay, register a Tunerpro,
download xdf here http://www.speedzilla.com/forums/ducati ... -free.html
use your chipburner and go.
PostPosted: Fri Apr 22, 2016 9:31 am
have had no luck with Chinese chips, way too many counterfeits. I believe I posted earlier on where to get the correct chip or how to upgrade to a more current and readily available chip
Cheapest P8 I have run across is still 300. The Aduino is 40 and has much more capabilities
PostPosted: Mon May 02, 2016 11:16 am
Just a progress report up and running now comes the wiring up of sensors
details
Arduiino mega 2560/Speeduino/Tuner Studio
Plan to add bluetooth in the near future
What you will get is flexible and configurable fuel and ignition management that will work for the majority of every day type setups. Currently supported features include:
16x16 3D fuel and ignition maps, with base of either TPS (Alpha-N) or MAP (Speed Density)
Supports up to 8 cylinders fuel and ignition with 4 channels of fuel and 4 channels of ignition outputs
1, 2 (Even fire only), 3, 4, 6 (even fire only) and 8 cylinders
After Start Enrichment
Rev limiting (Spark based, hard and soft)
Cranking specific enrichment, dwell timing and advance
General logging through TunerStudio
High speed tooth logging
TPS calibration through TunerStudio
Sensor calibration through TunerStudio (Coolant, IAT and O2)
Warm Up Enrichment (WUE)
TPS based acceleration enrichment
Tacho output
Fuel pump activation/deactivation (With priming)
Over dwell and over duty protection
Battery voltage compensation for dwell and injectors
Modular wheel decoder support. Included decoders:
Missing tooth (Eg 36-1, 60-2 etc)
Basic distributor (Fuel only)
Open loop idle control (PWM and Stepper)
Open loop boost control
Open loop VVT control
Semi-Sequential or Simultaneous injection
Deceleration fuel cut off (DFCO)
O2 based autotune (Registered version of TunerStudio required)
Did I mention GPS will also be included :cool:
PostPosted: Tue May 03, 2016 5:22 pm
the next step is the most complicated but not difficult. All the input/output signals from the Ducati sensors/drivers need to be conditioned to communicate with the Arduino board. This board will act as a place to hook up the Ducati wiring for both inputs and output signals. It is akin to adding relays to the wiring to save the ignition switch and solve the low voltage coil and headlight issues many of you have dealt with but with smaller components on a breadboard.
Also will have to decide weather to utilize the known troublesome 907 map sensor or to install a more modern one on the board for additional 20 bucks or so
PostPosted: Sun May 15, 2016 10:32 pm
All the component parts are in, just waiting on the breadboard. Once built progress should move along quickly :thumbup:
looking in to which wide band O2 sensor is best in the price vs quality category
suggestions are always welcome :beer: Of course this assumes anyone cares :phone:
Once this project is finished I will be revisiting the Weber DNCF issues and maybe a replacement for the ignition controller on the 906 and 750 :idea:
PostPosted: Mon May 16, 2016 3:03 pm
"Modular wheel decoder support. Included decoders:"
What is that?
Skip 907 MAP, use a sensor f e mounted under dash, I did.
Bosch wideband O2 is what most use.
PostPosted: Mon May 16, 2016 3:14 pm
PostPosted: Mon May 16, 2016 8:28 pm
the originator of the speeduino board has posted a youtube video of the board assembly
PostPosted: Mon May 16, 2016 9:25 pm
just another informational video on the Speeduino/Arduino Project
PostPosted: Tue May 17, 2016 10:00 am
This looks interesting, an open source wideband controller
:thumbup: :thumbup: :beer: :beer:
PostPosted: Wed May 18, 2016 5:53 am
PostPosted: Wed May 18, 2016 8:21 am
Yes he has recently joined the open source world :beer: :beer:
PostPosted: Thu May 19, 2016 5:35 am
You guys are amazing ! I have no clue what you are doing, but you seem to have fun :mrgreen:
