ducatipaso.org • View topic - Ducati Diagnostic Instrument
It is currently Thu Oct 29, 2026 4:57 am
 Post subject: Ducati Diagnostic Instrument
PostPosted: Thu May 26, 2016 10:31 am
Hi everyone
My back cylinder has gone quiet. :mad:
There's plenty of compression and spark, so am thinking there may be some kind of timing (crank angle sensor) or fuel issue.
My workshop manual talks about a diagnostic tool; blinking light variety, plugs in at the engine management unit, to check the condition of sensors. Does anyone know where I can source one, or how to make one up? Goofgling hasn't helped so far. I'm guessing the plug/cable is an industry standard type. Any advice would be much appreciated.
Mike
 Post subject: Re: Ducati Diagnostic Instrument
PostPosted: Thu May 26, 2016 3:12 pm
Can't help you with the diagnostic but I think if the crank or timing sensor has failed it will affect the spark and injection to both cylinders.
PostPosted: Thu May 26, 2016 9:28 pm
PostPosted: Thu May 26, 2016 11:29 pm
:thumbup: seems to me I saw a diagram on one of the other Ducati forums on how to craft your own version, do a google search and you should be able to find it
PostPosted: Thu May 26, 2016 11:55 pm
There is a schematic on how to build one on here too. It works too! Takes about $10 of parts and about 20 minutes to solder up.
Cheers.
Nick.
PostPosted: Thu May 26, 2016 11:59 pm
Try this post:
viewtopic.php?f=3&t=2558&hilit=flashing+light
Cheers.
Nick.
PostPosted: Fri May 27, 2016 8:27 am
chances are this tool is not going to help much, time to start check those connectors and grounds
concentrate on the ignition circuits and key switch :beer: :beer:
PostPosted: Fri May 27, 2016 8:34 am
PostPosted: Sat Jun 04, 2016 11:48 pm
Thanks for the responses guys.
Haven't looked at the bike for a week or two now, although I did quickly run a compression test on the rear cylinder; 125psi. So that's doesn't seem likely to be the problem.
As I mentioned in my op, there is a big fat spark at the rear cylinder, so I'm discounting CDI/ignition circuit issues at the moment and am starting think about fuel. Bike is just sittng in the corner of the garage atm, with a sheet over it.
