ducatipaso.org • View topic - Removing brake calipers
It is currently Tue Jun 16, 2026 9:17 am
 Post subject: Removing brake calipers
PostPosted: Thu Jun 02, 2016 3:35 pm
Hello,
I tried to remove the front brake calipers on my 750 Paso yesterday. Was in for a real surprice.... realized the calipers could not be removed unless taken apart or brake disks removed. There was simply not head room between the brake disk and the rim to remove the caliper in one piece....
for sure, the development Engineers and Tamburini did not have the maintenance aspects top of mind when designing the Paso - but in this case I could not belive my eyes .... :banghead:
The only reasonable conclusion I can draw, is that a previous owner of my bike has changed calipers and/or disks from original ..... or...?
 Post subject: Re: Removing brake calipers
PostPosted: Thu Jun 02, 2016 6:23 pm
Hi Isak, its normal that the calipers wont come off. You have pull a bit at the calipers so that the brake pads will move away from eachother. Then you can just take the caliper off the disc.
PostPosted: Sun Jun 05, 2016 12:31 pm
Moderator stepped in..? lol
PostPosted: Sun Jun 05, 2016 1:43 pm
kindergarten ...
PostPosted: Sun Jun 05, 2016 7:22 pm
:thumbup: :thumbup: :thumbup:
PostPosted: Sun Jun 05, 2016 8:42 pm
Huh ? all my best work disappears when the moderators "step in " :D I guess if you start a thread by giving us ( me anyhow ) immediate reason to doubt ones mechanical ability and then try to blame that on the bike and the engineer , your bound to attract some neutral/negative comments .Anyone that thin skinned shouldn't be riding a motorbike ...........probly should just stay inside and knit :)
PostPosted: Sun Jun 05, 2016 10:47 pm
G, pearl one nit 2
PostPosted: Mon Jun 06, 2016 4:41 pm
