ducatipaso.org • View topic - fule pump
It is currently Tue Oct 27, 2026 5:25 pm
 Post subject: fule pump
PostPosted: Mon Jul 25, 2016 10:19 pm
hi there
i am a newbie to actually fumbling around with a bike, i am loving it - but i have some funny question.
does the fuel pump of the 907ie make sounds when the ignition switch is turned .. or do i confuse this memory with the 996 i owned?
i have a 907ie since 1997 and did not treat it very nicely, so it has been in storage for the last 7 years. my plan was now getting her up and running again and then have a ride to my duc dealer to change the belts and then possibly ride or sell her. (depending on my wife :) )
now changed all the fluids and the oilfilter and got a new batteries and replaced the gas out and in flow tubes, they dissolved at the ends and were messy. Now the engine turns but doesn't ignite, the plugs seem to work - i at least got electrocuted when i checked for sparks. my current guess / hope is that the problem is electric to the gas tank or the fuel pump - hence my initial question. Any input is appreciated.
cheers
 Post subject: Re: fule pump
PostPosted: Tue Jul 26, 2016 2:50 am
PostPosted: Tue Jul 26, 2016 7:34 am
thank you, good lead - i guess a simple volt meter should do... will let you know
PostPosted: Tue Jul 26, 2016 8:06 am
The lack of fuel pump operation may simply be the relay or, as an acquaintance with an 851 found out after leaving it unused for 10 years found out, the hoses in the tank may have disintegrated and gummed up the pump. Hopefully something simple.
PostPosted: Tue Jul 26, 2016 10:05 am
hi Derek, hope so and the gummed up pump might well be since i had lots off gumm comming off the hoses on the fuel lines. just have a hard time dismanteling the pump and filter inside the tank... what a strange idea to stick that stuff in there..
PostPosted: Tue Jul 26, 2016 8:37 pm
Hi, so i checked the power and even though the cabling is poor and needs to be rewired the tank got power.
1. can / should i rewire myself or does anyone have a tip where to get Part #51010271A-Probewiring ?
2. what should my next step or test be? taking out the pump and cleaning it according to the manual in the manual section actually talking about a K-BMW?
3. and before i start further fumbling around with this tank, is there do or dont's on how to take this thing out of the tank and possibly put it in again later?
4. should i also change the filter, since it is out already?
yes i am in over my head :D ... oh and btw
5. what do you think about the belts they have nearly no mileage on them but obviously are older then 2 years- let change?
cheers Lorenz (wanted to attach pics but didtn work..)
PostPosted: Wed Jul 27, 2016 3:31 am
PostPosted: Wed Jul 27, 2016 3:28 pm
got you ... and any tip how to take out and put back in with big hands?
PostPosted: Wed Jul 27, 2016 7:46 pm
Take the filler cap off for a little more room
PostPosted: Wed Jul 27, 2016 8:24 pm
thanx to turkey hill ice tea country :) - should that still exist
.. found also following post -> Post subject: Fuel pump removal . wasnt aware it was a clip.. thought i had to screw..
now for testing the fuel pump ... or the delivery system... cheers
PostPosted: Sun Jul 31, 2016 6:39 pm
disassembled and rebuilt the fuel pump .. everything back together and... the pump seams to work :).. but the battery is now too drained to actually see of she is starting. lets see tomorrow. t
PostPosted: Sun Aug 14, 2016 7:38 am
pump worked engine started :) , smoking - probably oil issue in front cylinder. when i got time i will taking the cylinder head down.
