ducatipaso.org • View topic - battery suggestions?
It is currently Thu Jun 18, 2026 12:16 am
 Post subject: battery suggestions?
PostPosted: Tue Nov 04, 2014 12:22 am
Anyone recommend a good sealed gel battery? My bike had recently started misfiring (cutting out for a second) at forest sporadically now note frequently, under load, and now the battery died. So hoping the dying battery was causing the cutout.
 Post subject: Re: battery suggestions?
PostPosted: Tue Nov 04, 2014 10:33 am
Deka is a very good quality glass mat around 80 bucks in the US if you shop around
PostPosted: Tue Nov 04, 2014 12:29 pm
Motobatt are the battery of choice at the moment.
AGM (Absorbed Glass Matt) means they are leakproof and the Motobatt batteries have a higher capacity and higher CCA than the OEM.
PostPosted: Tue Nov 04, 2014 2:46 pm
Thanks gents.
PostPosted: Wed Nov 05, 2014 4:44 am
PostPosted: Tue Nov 18, 2014 4:43 pm
I put a motobatt in my 999 and wasn't impressed. Started losing charge after 1 year and needed replacing after 2. I keep my batteries indoors in winter and charge them up monthly. Got a Yausa in it now.
PostPosted: Wed Nov 19, 2014 12:16 am
I ended up with e Bikemaster Gel. Doubles as a boat anchor.
PostPosted: Sun Jul 24, 2016 3:11 am
I just tried to put a motobatt Mb16au in my 89 750 sport to replace my YB16AL-A2. The motobatt is about 2mm thicker and flat out doesn't fit in my bike. Maybe I could bend the regulator mounts and force it in but I'd have a hard time changing the regulator if I did so. Just FYI.
PostPosted: Mon Jul 25, 2016 8:19 pm
Got the motobatt in mine, a really snug☺ tight fit but all ok, getting it back out will be a whole lot worse...
PostPosted: Wed Jul 27, 2016 4:12 am
Would you be able to do me a favour and send a picture by any chance? Is your regulator/rectifier mounted in front of your battery? Mine is so I can't insert the battery at an angle without it hitting the bolts that hold the regulator.
PostPosted: Wed Jul 27, 2016 8:56 pm
PostPosted: Thu Jul 28, 2016 4:14 pm
I dont think these pictures will be a great help without the tank off :-(
PostPosted: Fri Jul 29, 2016 8:54 am
Oh no, they help alright. Thanks :)
I see you don't have your R/R mounted on the two brackets welded to the frame in front of your battery. It's those that stop me getting the battery in (the battery has to go in at an angle because it's slightly wider and it hits the bolts that hold my reg on).
I think I'll have to ditch it. Where's your R/R? Under the seat?
PostPosted: Fri Jul 29, 2016 8:11 pm
The R/R needs good airflow, as it gets hot. If you move it, make sure there is good airflow over it. Also make sure the case is grounded well.
PostPosted: Sat Jul 30, 2016 8:02 am
Oh, absolutely. I meant I'll have to ditch the battery, not move the reg. :)
