ducatipaso.org • View topic - male rod end bearings w/ M8 and 10mm bore?
It is currently Mon Oct 26, 2026 9:40 am
 Post subject: male rod end bearings w/ M8 and 10mm bore?
PostPosted: Tue Sep 13, 2016 8:16 am
usually bore size and thread are the same but they also exist in versions with smaller bore and larger thread.
So male rod end bearings with 8mm bore and M10 thread exist but the opposite is what I`d need.
Do these exist? I couldn`t find any.
 Post subject: Re: male rod end bearings w/ M8 and 10mm bore?
PostPosted: Tue Sep 13, 2016 12:24 pm
so you are looking for an M10x1.5 with a 10mm bore ?
or an M8 with a 10mm bore ?
also right or left threaded ?
PostPosted: Tue Sep 13, 2016 1:44 pm
I`m looking for M8 (right) thread and 10mm bore
PostPosted: Tue Sep 13, 2016 2:58 pm
Gerhard,
Not to my knowledge ... :(
Not possible to have a workshop bore/mill the joint (tricky) ?
Have no idea whether the forces/load are high ....
PostPosted: Tue Sep 13, 2016 4:07 pm
Try Aurora Bearing
They are the largest rod end bearing company on the planet
PostPosted: Tue Sep 13, 2016 9:26 pm
http://www.wiberger.se/templates/laenkhuvuden-ga.htm
http://www.wiberger.se/templates/gasw_fe-lankhuvud.htm thinner model.
In my hometown, bought 2 to my Monster.
I can buy and send to you if you find one that´s proper.
PostPosted: Wed Sep 14, 2016 10:38 am
thanks Steve & Gert but all I find there are rod end bearings that have the same thread diameter & bore.
Really seems 10mm bore with M8 thread does not exist. I`ll check shops that sell kart sport parts now.
PostPosted: Wed Sep 14, 2016 12:52 pm
maybe you could just reduce the thread size of a 10mm with an insert ?
or fill it and tap it ?
maybe the simplest way to go, fill and tap not sure you can find a helicoil or timesert to suit
PostPosted: Wed Sep 14, 2016 1:36 pm
but I need a male
PostPosted: Wed Sep 14, 2016 3:33 pm
even easier, just run a tap over the 10mm
