ducatipaso.org • View topic - Clutch master cylinder
It is currently Thu Feb 26, 2026 4:33 am
 Post subject: Clutch master cylinder
PostPosted: Thu Nov 10, 2016 9:20 am
Need to over haul my master cylinder, assume its a Brembo, what diameter is the bore/any part numbers? many thanks Pete
 Post subject: Re: Clutch master cylinder
PostPosted: Thu Nov 10, 2016 9:41 am
I'm pretty sure you need a PS13 seal kit but it may be a PS12. Both are available from Gutsibits
PostPosted: Thu Nov 10, 2016 4:45 pm
have a look at the bottom side of the pump. There should be a number stamped on the housing.
PostPosted: Fri Nov 11, 2016 8:30 pm
thanks, will have a look weekend...
