ducatipaso.org • View topic - New Thermostat
It is currently Sat Feb 28, 2026 12:01 pm
 Post subject: New Thermostat
PostPosted: Wed Nov 16, 2016 10:01 pm
Will a 998 thermostat work on a 907ie?
Thanks in advance
 Post subject: Re: New Thermostat
PostPosted: Thu Nov 17, 2016 9:09 am
If you could get it to fit yes, but the orientation of the 90ยบ outlet is wrong and won't line up with the 907 pipe. A thermostat from an 851 will fit - if you can find one.
It may be worth exploring thermostats from the Aprilia range. Many of these use similar thermostats, one of which might have the same configuration.
PostPosted: Thu Nov 17, 2016 9:38 am
If you would try to install the 998 thermostat the side exit would show forward instead of towards the rear of the bike.
What`s the diameter of the hose connections of the original thermostat and what`s the opening temperature (which is stamped on the housing)?
You can put car thermostats in ketchup for 15min after scraping the hard stuff off. Descaler or molasses might work as well. The question is how long it will continue to work.
PostPosted: Thu Dec 29, 2016 6:05 am
I found an 851 thermostat and it's working fine. Thanks a million
