ducatipaso.org • View topic - where to get brass freeze plugs
It is currently Mon Oct 26, 2026 10:44 pm
 Post subject: where to get brass freeze plugs
PostPosted: Mon Nov 21, 2016 4:39 pm
I need help finding freeze plugs to complete the engine rebuild and have had no luck with searches. it looks like I need 16mm and 18mm brass but cant seem to find a place to buy them. any help would be greatly appreciated.
 Post subject: Re: where to get brass freeze plugs
PostPosted: Mon Nov 21, 2016 6:34 pm
from another Duc forum:
"87310201A 20mm
87310051A 18mm
87310011A 16mm
87310021A 10mm
If you type in Ducati then the part number (without the 20/18/16/10 etc) you should find a few that sell them."
I assume shops that build engines or shops for agricultural machines should have these, too.
This is a great site for parts cross reference: . Just copy and paste the part numbers into the last field and you get an overview in which newer models these parts were also used.
