ducatipaso.org • View topic - anodizing footpegs & brackets?
It is currently Thu Oct 29, 2026 12:58 pm
 Post subject: anodizing footpegs & brackets?
PostPosted: Tue Dec 06, 2016 5:49 pm
did someone do that and can show the result. Apparently some shops say that anodizing these cast parts would not have a good result.
 Post subject: Re: anodizing footpegs & brackets?
PostPosted: Wed Dec 07, 2016 3:00 am
A bead blast and a clear coat brings em up a treat , if NASA knew about this there would have been a pair on the shuttle :D
PostPosted: Wed Dec 07, 2016 5:44 am
PostPosted: Wed Dec 07, 2016 6:46 am
+1 gotta do the prep
PostPosted: Wed Dec 07, 2016 9:03 am
prep work is definitely the most important thing. I had several parts anodized in the past so it`s not new to me. Most were machined parts and hence no problem. All were sanded and polished to high gloss before anodizing to give a nice deep shine. Then I had a set of cast carb manifolds which were beadblasted only. I wanted to have them anodized black and the result was pure charcoal. An absolut dry flat black. Polishing them too might have done the trick but I`m not sure. Many parts react a bit different to anodizing which can lead to a different colour tone or even spots. That`s why I would actually like to see some that were restored.
PostPosted: Wed Dec 07, 2016 11:04 am
The problem is that if the alumnium alloy contains silicon (Si), this silicon will not oxidize but instead become coal black.
Most alloys used for casting do use silicon.
my problem is that I do not know the composition/alloy of the alumnium used for the pegs, swingarm (multiple), handlebars and triple clamp nor do I know how to find (non distructive) out IF parts contain silicon.
Also the acid used for the anodization process has a distinct influence on the discoloring of the anodising layer.
If your anodidising company is prepared playing with the composition of the acid bad you have a chance to get it right (after all: these parts were anodized), but I haven't found one.
Would love to find a company who could anodise these parts again (clear that is), maybe someone in the UK?
PostPosted: Thu Dec 08, 2016 6:09 am
Anodizing cast parts works just fine, but the appearance is difficult to predict and may be splotchy, especially if dark colors are chosen. Tumbling or bead blasting will improve the consistency of the appearance. Acid etch will also help. Matte finish is generally better than attempting a shiny surface.
I have had to coach several clients that have ordered anodized die cast parts about appearance. Rarely does that talk end up well.
Lowered expectations reduces disappointment.
PostPosted: Thu Dec 08, 2016 7:26 am
Hi Phil,
You seem to have more experience then I, how did our parts on the Paso got that shiny look? :?:
The company which I showed the swingarm told me that some parts of the swingarm were most likely anodized (before welding) and some were not (cast parts)?!
I got them bead blasted and later ballpolished so they were pretty shiny, after that I painted them with a 2K clear coat but that's nowhere near as strong/robust as the anodisation layer. :(
Did read something about Exo-armour (2K), but seems to me to be not stronger then the 2K clear coat I used on the swingarm.
on the pegs, triple clamp etc. I used the clear powdercoat, but still believe that that is not 100% moisture proof (like coated rims: if moisture comes under the clear ....). :dunno:
PostPosted: Thu Dec 08, 2016 9:30 pm
The stock parts were anodized, and had a silver colorant added most likely, and a clear sealer coat. Silver/aluminum colored parts should work just fine. Surely the stock finish of the Paso parts would not pass inspection for Apple these days, or companies like MV Agusta. The swingarm has cast and extruded parts, and were welded together before anodizing. Can't weld parts after anodize.
