ducatipaso.org • View topic - Paso 20mm swingarm pivot modification
It is currently Tue Mar 03, 2026 7:33 am
Post new topic Reply to topic  [ 24 posts ]  Go to page 1, 2  Next
 Post subject: Paso 20mm swingarm pivot modification
PostPosted: Mon Dec 19, 2016 11:20 pm
I found that the Paso has a 15mm swingarm pivot. That is very small especially considering that all other Ducati models since 1990 they have used a 20mm pivot. So I decided that I wanted to upgrade.
This would require modifications to the frame and the bearings in the swingarm.
 Post subject: Re: Paso 20mm swingarm pivot modification
PostPosted: Mon Dec 19, 2016 11:22 pm
I found a 20mm axle from some Japanese bike was very close in spec to the Paso pivot.
PostPosted: Mon Dec 19, 2016 11:23 pm
My plan was to bore out the frame but it was impossible to fit in a milling machine. So I made fixtures that allowed me to drill out the holes in steps.
PostPosted: Mon Dec 19, 2016 11:25 pm
Measuring the inside of the frame I realized that there would be very little surface area left so I had cups machined that I welded over the original pivot area.
PostPosted: Mon Dec 19, 2016 11:28 pm
Modifications to the bearings in the swingarm were pretty straight forward. Sourced some new bearings and made a few new spacers.
PostPosted: Mon Dec 19, 2016 11:31 pm
I had to turn the head of the new pivot down slightly to fit down the frame pocket.
On the other side I had to source a small OD flange nut.
Everything fit so I could install the black plastic caps.
PostPosted: Mon Dec 19, 2016 11:32 pm
This should make for a much stiffer chassis.
PostPosted: Mon Dec 19, 2016 11:34 pm
I absolutely love shit like this, Well done and brilliant photo's and explanation I think G will be putting this in the FAQ thread pretty soon :thumbup: :thumbup: :beer:
PostPosted: Tue Dec 20, 2016 3:28 am
I love shit like this too , more the psychiatric side of things than anything to do with motorcycle engineering . I mean your obviously no dummie when it comes to making things outa metal but if you really wanted to stiffen up the chasis you shoulda just painted it , any how , nice job ...... if you must :) :)
PostPosted: Tue Dec 20, 2016 4:52 am
The frame will be powder coated once I finish the rest of the modifications to install the 999S motor
PostPosted: Tue Dec 20, 2016 5:22 am
Oh yeah ! I can so see why you'd want to do that. :idea: Have you thought about fitting the Paso body work to a 999s ?
PostPosted: Tue Dec 20, 2016 11:13 am
Hi, soory but maybe I've missed it: how did you solve it with the bearings in the engine case?
Also, what is your main reason to go from 15 to 20mm?
PostPosted: Tue Dec 20, 2016 11:57 am
PostPosted: Tue Dec 20, 2016 12:10 pm
Ok, missed that (the 999 engine).
Wow, quit a project!
Assume that adapting the swingarm bolt is the easiest modification :thumbup:
Will be interesting to see the project in progress!
Good luck :beer:
PostPosted: Tue Dec 20, 2016 12:29 pm
Speedmade, don`t mind me asking but seeing that the thread of the 20mm pivot is longer I wonder which part of it sits in the frame. Hope you get what I mean. (if it`s the threaded part it could cause radial play, which may be gone if all is tightened up, but still...)
Users browsing this forum: Bing [Bot] and 3 guests
