ducatipaso.org • View topic - 907IE Fuel Tank Wanted
It is currently Fri Feb 27, 2026 7:28 pm
 Post subject: 907IE Fuel Tank Wanted
PostPosted: Sun Dec 18, 2016 7:18 am
New or good secondhand 907IE tank wanted. Paint condition not that important but must be rust-free internally.
Thanks.
RB
1980 LAVERDA JOTA
1982 HESKETH V1000
1985 LAVERDA SFC 1000
1993 DUCATI 907IE sold May 2017
1993 DUCATI 907IE sold September 2017
1995 TRIUMPH DAYTONA SUPER III
 Post subject: Re: 907IE Fuel Tank Wanted
PostPosted: Mon Dec 19, 2016 11:03 am
if the picture is correct the description isn`t and it`s a 907ie tank
http://www.ebay.com/itm/1986-1989-Ducat ... CB&vxp=mtr
PostPosted: Mon Dec 19, 2016 2:10 pm
RB
1980 LAVERDA JOTA
1982 HESKETH V1000
PostPosted: Tue Dec 20, 2016 10:51 am
If that is indeed a 750/906 tank I don`t understand why it has the 907ie design, specially as it is new and unused.
But then maybe it was a late friday afternoon and someone in the factory didn`t pay attention ...
Have you tried to send an email to Rudy?
PostPosted: Tue Dec 20, 2016 11:06 am
That is defo' a 907ie tank if you read the description there is some outer cardboard panels sprayed over on the underside that hide the other relevant apertures. That would not fit a 906 or 750 unless you adjusted the Petcock attachment for the fuel supply.
sadly even at £260 with the 50% discount it's a whole lotta money for a fuel tank.
PostPosted: Tue Dec 20, 2016 12:02 pm
there`s one picture taken through the filler hole. That on the right is the mount for the electric fuel pump.
The description confuses me a bit. Maybe there were different 907ie gas tanks.
viewtopic.php?f=3&t=6864&hilit=inside+tank
PostPosted: Tue Dec 20, 2016 6:07 pm
RB
1980 LAVERDA JOTA
1982 HESKETH V1000
PostPosted: Wed Dec 21, 2016 12:35 am
The shot through the fuel cap hole shows a very limited view of the fuel pump mount, and the clips where the degasser sits too.
The shot of the bottom of the tank is a bit odd, or I may have missed it. The return line is there, the hole for the NRV is there, but only one breather is there? 95% rule (close enough is good enough!)?
A little while back G posted a French bike shop that had various parts. The Web site was http://italbikeshop.fr/
If it comes good, I will have one in Anthracite please....
Hope it helps.
Cheers.
Nick.
PostPosted: Wed Dec 21, 2016 10:01 am
There is a variation in 907 tanks. I have seen one with a single breather while most have 2.
PostPosted: Wed Dec 21, 2016 7:31 pm
Since the tank on my 907 is currently unbolted with the hoses disconnected I had a look at the underside. Unlike the one in on eBay it has 4 hose fittings. From the front they are fuel delivery, fuel return, drain, vent. The one on eBay appears to be missing the drain pipe.
This a picture of the underside of my tank.
PostPosted: Wed Dec 21, 2016 9:39 pm
I have one on stock.
Please send e-mail to info@duc-only.nl
PostPosted: Wed Dec 21, 2016 10:53 pm
RB
1980 LAVERDA JOTA
1982 HESKETH V1000
PostPosted: Sun Dec 25, 2016 9:01 am
I also have a brand new red 907 tank if you need one. Bought it new from Bologna years ago. Unfortunately there is a small dent at one of the front corners due to transportation damage.
Cheers, Mark
