ducatipaso.org • View topic - problem with idling
It is currently Fri May 01, 2026 8:23 am
Post new topic Reply to topic  [ 23 posts ]  Go to page 1, 2  Next
 Post subject: problem with idling
PostPosted: Tue Feb 14, 2006 8:03 pm
Hello everybody, this is my first post on the forum. I am driving a stock 93 mod 907ie wich the last couple of years have had a problem idling, the problem appears both with warm and cold engine it just make no diffrence. At idle it runs ony a few seconds before it dies.
My mechanic have tried fixing it a couple of times without any sucess and have run out of ideas I think, what he says is that it seem to be the rear cylinder that dies..
The bike has new plugs and filters (fuel&oil&air). Valves are adjusted and within spec., I have tried adding CRC in the fuelsystem to clean the injection jets without any noticeable effect.
Im not sure but i think the engine is running a bit hotter than it used to do before.
Except this problem it runs great and i really hope someone has a good advice where to start searcing for the problem.
Haavard
PostPosted: Tue Feb 14, 2006 10:39 pm
Rogero
1992 "Red" 907 I.E.
PostPosted: Wed Feb 15, 2006 7:18 pm
PostPosted: Wed Feb 15, 2006 9:24 pm
Rogero
1992 "Red" 907 I.E.
PostPosted: Wed Feb 15, 2006 9:53 pm
PostPosted: Thu Feb 16, 2006 6:43 am
PostPosted: Thu Feb 16, 2006 6:47 am
PostPosted: Thu Feb 16, 2006 6:54 pm
PostPosted: Thu Feb 16, 2006 6:57 pm
Rogero
1992 "Red" 907 I.E.
PostPosted: Thu Feb 16, 2006 7:18 pm
PostPosted: Thu Feb 16, 2006 10:45 pm
Rogero
1992 "Red" 907 I.E.
PostPosted: Fri Feb 17, 2006 11:24 am
PostPosted: Thu Feb 23, 2006 8:44 am
Ok - I will.
907 service manuals I've found on sites for about $68. Before I order one is there a better source. I'm determined to do more myself ( or at least give it a try!! )
Thanks in advance.
Rogero
1992 "Red" 907 I.E.
PostPosted: Thu Feb 23, 2006 12:51 pm
Hi Rogero,
where have you found the service manual?
No matter, it seems to me you need also of 906 manual, 'cause the 907 manual would be only an addition to the 906 manual.
PostPosted: Thu Feb 23, 2006 7:02 pm
$68 - seems OK to me. Not sure how much they'll charge for shipping to the UK.
Rogero
1992 "Red" 907 I.E.
