It is currently Wed Feb 25, 2026 7:19 am
Post new topic Reply to topic  [ 509 posts ]  Go to page Previous  1, 2, 3, 4, 5 ... 34  Next
PostPosted: Tue Jun 20, 2017 8:18 am
Absolutely, probably be sometime before I get all the bits together and cleaned for reassembly, don't spouse you have the how to on remove oil sight glass, due to paint buildup on the ext of case I can't see clearly if there is a circlip
PostPosted: Tue Jun 20, 2017 9:09 am
Yep cleaned it up and tapped it out, hope I can get a new one as she's stuffed now,happy days
PostPosted: Tue Jun 20, 2017 10:52 pm
Part of the reason of doing these gaskets and seals myself being fresh engine enamel not brought to temp yet , I can rework the paint before she is reassembled, also to learn a little more about what I believe will be a bloody great motorcycle
PostPosted: Tue Jun 20, 2017 11:45 pm
PostPosted: Wed Jun 21, 2017 12:21 am
Oh shit to be honest I didn't think they would be all that hard to get
PostPosted: Wed Jun 21, 2017 3:16 am
yeah,and I thought I would wander into SKF and get into a discussion as to why they only sold them in packs of 10 :D
http://www.ebay.com/itm/Ducati-OEM-Oil- ... Tx&vxp=mtr
just found this so panic over ( there are others there too ) :)
PostPosted: Thu Jun 22, 2017 12:21 am
Thanks , been enough tough searches on the 89 , are ventilated clutch covers available for this model, also want a new clutch cable , hopefully something a bit prettier than the old rubber coated original?plenty of time as here in the west works a bit light on so not able to bike shop much, got time but
PostPosted: Thu Jun 22, 2017 1:38 am
I got spiegler brake lines but I guess they didn't have the clutchline, always get one made up I guess,should I spray the open cases with wd 40 or so as could be open for a while
PostPosted: Thu Jun 22, 2017 9:46 am
Engine repainted ... pictures??!! :thumbup:
PostPosted: Thu Jun 22, 2017 12:33 pm
Trying to post photos but my tech skills are extremely bad, I will try to get some help with that, the paint was real crap so I handsanded the whole lot and sprayed with Dupli Color engine enamel with ceramic / semi gloss black, come up sweet as a nut, valve covers same paint/ universal gold
PostPosted: Thu Jun 22, 2017 12:47 pm
I polished the cam covers, forks and billet ally triple clamps , cam covers look nice on the black engine
PostPosted: Thu Jun 22, 2017 1:54 pm
Mine I painted with VHT engine paint and the lids were powdercoated (black relief) ...
Wish I could upload higher res. (Now max is 1024/786). :dunno:
PostPosted: Thu Jun 22, 2017 11:03 pm
Looks really nice all black and a splash of silver nuts , bolts / fittings and raised lettering filed off?
PostPosted: Fri Jun 23, 2017 7:46 am
No, didn't file of the raised lettering, I like it black and discrete.
Just ordered a new sticker (Australia) and used electro polished stainless steel bolts and (cylinder) nuts, which shine almost like chromed.
The top lids (valve covers) are a cheap alu/zinc alloy and were a bit corroded so I decided to make them mat black so it doesn't stand out.
All steel items are re-galvanized.
Main goal was to get a "like new" engine (I have overhauled the engine; new clutch and clutch mechanism, new gaskets, bearings and seals, complete cylinder heads overhauled) but no frills, just a taut engine.
I'm trying to improve the look of the Paso with the fairing removed (small changes), with improved brackets for coils, fuel pump (vacuum), new (black) Aeroquip oil lines, new polished stainless steel fasteners, improved cabling etc. :thumbup:
PostPosted: Sat Jun 24, 2017 1:29 am
Ah Frank , the whole point of fitting a fairing to the Paso was coz it looks like shit without one :D :lol:
yours does look real good tho :)
