It is currently Tue Apr 21, 2026 9:59 am
| Author |
HIGHWAY89
Post subject: Re: Oil leaks 89 900 ss Posted: Mon Jul 03, 2017 2:39 am |
| paso grand pooh-bah |
Joined: Sat Jul 16, 2016 6:35 am Posts: 509 Location: Australia
The piston looks good just tarnished, feels reasonably smooth, the cylinder has like a buildup of tarnish which feels like little ridge areas, so far only cleaned it with paper towel, also so far I haven't been able to remove the circlip, I must employ someone's help to upload photos , surprisingly the amount of heat I used didn't seem to damage the seal or oring but yes they will be replaced
| Top |
HIGHWAY89
Post subject: Re: Oil leaks 89 900 ss Posted: Mon Jul 03, 2017 3:00 am |
Closer look at the big o'ring/seal it appears that it was not seated well , bit sort of twisted and looks as though it's been that way for some time, guess that wouldn't have helped
| Top |
HIGHWAY89
Post subject: Re: Oil leaks 89 900 ss Posted: Mon Jul 03, 2017 8:51 am |
Can't get bloody circlip out as I think last time somebody broke the bloody tangs off, looking at the pics you sent me as that one has tangs and my bitch don't!this whole bikes been like that, sorting through them one at a time
| Top |
HIGHWAY89
Post subject: Re: Oil leaks 89 900 ss Posted: Mon Jul 03, 2017 9:01 am |
Just glad I decided to do the gaskets or I wouldn't have known how bad the thing was and put up with it, this way a much better bike for it, if I can't get the clip out though , may end up having to shell out for a new one!once again any ideas greatly appreciated
| Top |
Post subject: Re: Oil leaks 89 900 ss Posted: Mon Jul 03, 2017 9:19 am |
this is going to be fiddly. You'll need to fixate the piston somehow and use two needles (or very thin screws) to get the circlip out. One is to stop one end of the circlip so it won`t turn while you try to push the other below the circlip in the groove. If you manage to get below it you have a chance to push it further below lifting the clip out of the groove or at least far enough that you can use a screwdriver to lift it out or grab it with pointed pliers
| Top |
HIGHWAY89
Post subject: Re: Oil leaks 89 900 ss Posted: Mon Jul 03, 2017 9:42 am |
Just what I' m trying but it's a real bitch, just abused and damaged brand new kincrome set of pics tried sharpening old ones, bent sharpened screwdrivers, had a second pair of hands as well, don't like giving up but i don't know what else to do, I will just keep annoying it, I may just worry it out
| Top |
Post subject: Re: Oil leaks 89 900 ss Posted: Mon Jul 03, 2017 9:47 am |
I`m wondering. Instead of trying from the broken ends is it possible to get behind the clip from the top?
| Top |
HIGHWAY89
Post subject: Re: Oil leaks 89 900 ss Posted: Mon Jul 03, 2017 9:57 am |
I will give it a go, THANKS
| Top |
HIGHWAY89
Post subject: Re: Oil leaks 89 900 ss Posted: Mon Jul 03, 2017 10:06 am |
You know the 2 flat sides on the piston skirt, just broke one , too much vice and wrestling no doubt, oh well don't have to worry about that clip anymore, to the person who put that clip in, fooey
| Top |
HIGHWAY89
Post subject: Re: Oil leaks 89 900 ss Posted: Mon Jul 03, 2017 1:22 pm |
My piston has flat sides on the fluid skirt, looks to be to take a c spanner or vice , I can't see that on your thread about these things, yours seems completely round
| Top |
HIGHWAY89
Post subject: Re: Oil leaks 89 900 ss Posted: Mon Jul 03, 2017 2:02 pm |
There is some scoring on the covers cylinder wall although it's quite high I don't suspect it will cause any problem I cleaned so far with a green scotchbrite pad
| Top |
HIGHWAY89
Post subject: Re: Oil leaks 89 900 ss Posted: Mon Jul 03, 2017 2:08 pm |
Looking on steines I think I will buy the slave piston complete and be done with it, I will put together another list, sightglass, gaskets etc, thanks for patience and help
| Top |
HIGHWAY89
Post subject: Re: Oil leaks 89 900 ss Posted: Tue Jul 04, 2017 11:58 am |
Having a closer look at alt side cover now , 1st thing I notice is the stator cable is 3 wires ext but 1 is cut back at the 2 terminal stator? Any one removed flywheel sightglass, I guess it's same as oil sightglass and just knock from inside ! And get a new one
| Top |
HIGHWAY89
Post subject: Re: Oil leaks 89 900 ss Posted: Tue Jul 04, 2017 12:14 pm |
Knockout, to be honest it come out ok too, but ext of seal is crap so will change that and gear shift seal too, now ready to fix paint and clutch side too, I am thinking bout drilling clutch cover some before I fix paint to that,finally getting through it, close to my next list of parts, then to sort out who to buy what off
| Top |
Users browsing this forum: No registered users and 14 guests |
