It is currently Sat Apr 25, 2026 9:29 pm
| Author |
1564
Post subject: 91 907ie back fire Posted: Tue Feb 21, 2006 7:44 am |
hello , been busy with 2nd toy 90 851w/2k as new cond. question to group my 91 907ie has a shotgun like back fire upon getting of the gas, it will back fire several times...all fluids,belts,values,electrical checks,fuel filter,spark plugs have been changed adjusted and or replaced...it runs very strong and idles well...only issue is back fire...has euro chip,open staintunes and airbox mod., have appointment with local ducati dealer...any thoughts or suggestions :ugh:
| Top |
Finnpaso
Post subject: Posted: Tue Feb 21, 2006 1:14 pm |
| paso grand pooh-bah |
Joined: Mon Jul 26, 2004 12:00 am Posts: 3081 Location: Finland
Have You done ALL needeed adjustments to INJECTION ????? :confused:
_________________ Antti http://www.youtube.com/watch?v=HeKOh3XoXPg&NR=1 KTM 990 Adventure -08 metal dark grey Paso 750 -89 red/metal grey Paso 907IE -91 red/metal grey Paso 907IE -91 red 2xST4S -02 red/metal grey ST2 -01 red/metal grey Volvo V70 Bi-Fuel Classic/titanium
| Top |
1564
Post subject: Posted: Tue Feb 21, 2006 2:35 pm |
have not touched computer/fuel injection...will have duc dealer sort that out...any thoughts
| Top |
Finnpaso
Post subject: Posted: Tue Feb 21, 2006 3:16 pm |
Most of that kind problems are connected to fuel/ignition system, thats why. Read close topic "problem with idling". U have changed/checked near all other possible things, so Injection should check next! Remember, that there are also "not so good" Ducati dealers, who cant find solution to problem, but surely they can take Your moneys easily....
Ps, Injection NEEDS, that Your battery is filled with current and it can also give it to system = Good battery and NOT clogged fuel filter are "MUST" in injected bikes !!! :thumbup:
| Top |
DesmoDog
Post subject: Posted: Tue Feb 21, 2006 9:41 pm |
Joined: Sun Feb 27, 2005 12:00 am Posts: 244 Location: Dexter, MI USA
My guess is it's the exhaust and if you check for leaks at the muffler/pipe junction, you'll find one... if not there check at the crossover and then head. Wildcard guess - all of the little plugs are still in the pipes, right?
If the bike's backfiring through the intake you probably have an issue with the mixture. The "Euro chip" probably isn't enough to compensate for the modified airbox and mufflers - you really need an aftermarket chip to keep the bike from running lean. Too lean and you can burn valves...
_________________ -Craig
| Top |
Finnpaso
Post subject: Posted: Wed Feb 22, 2006 12:51 pm |
| Top |
persempre907
Post subject: Posted: Wed Feb 22, 2006 9:09 pm |
| Top |
1564
Post subject: Posted: Wed Feb 22, 2006 10:43 pm |
| Top |
Rogero
Post subject: Posted: Thu Feb 23, 2006 8:38 am |
Joined: Fri Jun 17, 2005 12:00 am Posts: 314 Location: Cardiff, South Wales
70 degrees and sunny eh?
Well in the UK it's 41 degrees (F) and a bitterly cold North Easterly is blowing down into South Wales.
Too cold for 907's today - I'll take the car.
Hope the problem is solved, mine is chipped and goes well with open pipes....
_________________ Rogero 1992 "Red" 907 I.E. 2006 Harley-Davidson Dyna FXDBI (Street Bob)
| Top |
1564
Post subject: Posted: Thu Feb 23, 2006 2:39 pm |
just for information the 907 has a fim chip and puts out 14v at 5000rpm , new fuel filter and is always hooked up to charger... :rant:
| Top |
Finnpaso
Post subject: Posted: Thu Feb 23, 2006 7:58 pm |
Remember to check also COMPRESSION in both sylinders !!!! If its exhaust valve problem, then easy to check with compression test. :thumbup:
| Top |
The_Duke
Post subject: backfire prob Posted: Sat Feb 25, 2006 10:54 am |
| Top |
1564
Post subject: Posted: Sat Feb 25, 2006 5:08 pm |
| Top |
1564
Post subject: Posted: Sun Feb 26, 2006 7:18 pm |
| Top |
DesmoDog
Post subject: Posted: Sun Feb 26, 2006 7:37 pm |
| Top |
Users browsing this forum: No registered users and 26 guests |
