ducatipaso.org • View topic - Help finding a couple parts
It is currently Mon Jun 22, 2026 4:31 pm
 Post subject: Help finding a couple parts
PostPosted: Fri Jul 14, 2017 1:11 am
I am in the process of rebuilding my 1990 750 sport and it has cracks in the rubber belt covers. (pics) Anyone know where I can purchase a set or any other models that will fit.
Thanks in advance!
 Post subject: Re: Help finding a couple parts
PostPosted: Fri Jul 14, 2017 1:17 am
You could try Gowanlochs in Australia if same as89 900 ss as I had a price off him last year on those I think
PostPosted: Fri Jul 14, 2017 5:52 am
I looked into this a while ago as mine are the same. I think what happens is the cover screw ( repeatedly ) seizes in the metal( brass ? ) insert in the housing and the whole housing is deformed and eventually splits when someone leans on the screw to get it out . I seem to remember that there were some cool carbon fibre after market jobs for one of the 2 valve monster engines..................ebay maybe ?
PostPosted: Fri Jul 14, 2017 12:20 pm
Thanks for the tips, I will keep searching and let you know what I find.
PostPosted: Mon Jul 17, 2017 5:26 am
put a bit of moly lube on those bolts when you put them in to keep them from seizing up. or the copper anti-seize paste. That's why many old race bikes had copper plated fasteners. But zinc plate works well too. So if you change out those bolts to stainless, you need to add an anti-seize compound.
PostPosted: Sun Jul 23, 2017 7:59 am
PostPosted: Sat Jul 29, 2017 3:17 pm
