It is currently Sat Jun 20, 2026 1:35 pm
Post new topic Reply to topic  [ 509 posts ]  Go to page Previous  1 ... 4, 5, 6, 7, 8, 9, 10 ... 34  Next
PostPosted: Sun Jul 23, 2017 8:12 am
where are those yellow wires and which 2 terminals did you connect them to?
PostPosted: Sun Jul 23, 2017 11:24 am
Starting at the two terminals on the stator I have a yellow wire on each, there they going to the regulator, have to look back at old pics to see which goes to which of 6 pins there
PostPosted: Wed Jul 26, 2017 10:02 am
It seems someone changed the stator in the past. According to the wiring diagram (in the FAQs) the wires should be brown and black. Later Ducatis had two yellow wires.
The connections on the regulator/rectifier are pins 1 and 2.
If you have two yellow and one red it's the stator of the 750 Sport or Paso. If connected to your regulator (or an aftermarket unit) the red wire is (often) not used. I.e. see the installation instructions of the Electrex/Electrosport regulators https://app.box.com/s/r16ixjegwfl7aq3ybd0c
PostPosted: Fri Jul 28, 2017 3:37 pm
Thanks for that mate, it all makes sense now after seeing the diagrams there and checking old pics , diagram 1 is the go
PostPosted: Mon Jul 31, 2017 11:17 am
Had another peek at the reg info you posted and I see there you highlighted the bit on voltage, cheers
PostPosted: Wed Aug 23, 2017 12:34 pm
Well, I haven't done a damn thing to the 89 for a while, not much work so not buying parts, anyway got that bad I had to sell my 850 lemans 1 that I restored recently, a bloody sad day , funny thing is the guy that bought it had a 90 ss 900 years ago and was blown away as to how mine is looking on the bench,soon I will start to get some parts and close the engine back up and get serious with this again, start this thread going and be annoying you guys for more of your invaluable help, thanks
PostPosted: Thu Aug 24, 2017 12:02 am
PostPosted: Thu Aug 24, 2017 9:10 am
Cheers mate but it's all about this 900 ss now
PostPosted: Thu Aug 24, 2017 2:06 pm
Andrew, the 3 are a nice bike, I restored one 20 odd year ago and it was sensational, so good luck with that one, but like I said for me it's a new era, with my 89, have a good one
PostPosted: Thu Aug 24, 2017 11:53 pm
Good attitude mate. I tend to get too attached to my bikes. Your 900 will be a ripper when it's done.
PostPosted: Fri Aug 25, 2017 10:14 pm
Ahhhh , a (mk) 1 .........I don't like the square cylinder/head finning on the later Guzzi's .... so a 1 would be a real rench .......honestly I might have dumped the SS and kept the Guzzi :)
Huh , about 50 old tractors ( and a 4wd with a salvage trailer ) have just rumbled past my driveway.... which , along with this post made me think of the Guzzi website " this old tractor ".
anyhow SS's are also captivating and I wouldn't mind the challenge of getting that weber to work right ( its called fitting FCR's :) ) and the early ones have their own appeal too . I look forward to the completion pix :) :)
PostPosted: Sat Aug 26, 2017 4:09 am
I will kit the Mikunis for now with a plan to fit FCR'S later, bit disappointed that I fitted a new hagon (basic) shock, so I would like to update to Wilburs or Ohlins or such at a later date as well, no point doing these until she's finished and put through its paces, cheers for now, enjoy
PostPosted: Thu Aug 31, 2017 7:49 am
Starting to get on with it slowly, ie bought slave cylinder for clutch , really need new pc as sourcing parts on a mobile phone is b.s., cant wait to really get back into this build, had to get guzzi grieving done with 1st
PostPosted: Wed Sep 06, 2017 2:53 pm
Ordered all the parts needed to put both cases back on , seals gaskets orings and both sight glasses, steines were reasonable prices overall, protwin in perth will fit a stainless sleeve to match the new original slave cylinder and then drill the cover some . I've stripped and recoated the alternator cover ready for bearing , sightglass and all , I also have resoldered new 4mm tinned copper wires to the stator , good to be moving forward again, just gotta be patient waiting on parts to turn up, having fun again
PostPosted: Mon Sep 11, 2017 7:10 am
Clutch covers at proteins for sleeve and mill/ venting and clutch/ engine housing is prepared and painted waiting on parts due in a few days so fingers crossed I can button the whole thing up, waiting on a new liscense plate holder from Rudy then I can fit electric and refurbished wiring loom, cheers
