ducatipaso.org • View topic - Front brake master cylinder
It is currently Tue Mar 03, 2026 1:27 pm
 Post subject: Front brake master cylinder
PostPosted: Tue Sep 19, 2017 11:48 am
Hi everyone.
I have just replaced the old rubber brake lines with HEL stainless lines, and found a little problem in the process. Without the lines connected to the calipers, brake fluid runs out constantly without the brake lever pulled in. Makes it easy to bleed the air out, but doesn't seem right to me? I'm thinking the brake master cylinder needs a kit put through it. Does anyone know the Brembo part number of the kit? Or failing that, the Ducati part number?
I'm also thinking a radial brake master might be a reasonable upgrade, with a remote reservoir. Has anyone taken the plunge and fitted one?
Cheers.
Nick.
 Post subject: Re: Front brake master cylinder
PostPosted: Wed Sep 20, 2017 3:56 am
The fluid should run straight thru as you describe Nick . With the piston assy at the normal resting position the port from the resiviour to the cylinder should be open and the fluid will flow , if you pull the lever in a bit ( thus closing that port ) the flow should stop. Im pretty sure I have the correct Brembo kit somewhere so I will look it out and get the part # off it for you . Those kits are also available from MG's , just need to know the diameter. Some of the whole master cylinder assys are cheap enough to just put a whole new one on there :)
Hamish
PostPosted: Wed Sep 20, 2017 11:06 pm
Hi Hamish.
It seemed a bit odd the fluid ran through. I did look at a few master cylinders on eBay. The you beaut, straight from China are beer money, but quality could be an issue? I have a British Princess sitting next to the 907 and it has a radial brake master (hence the second question). I thought the 907 had reasonable brakes, but you don't realise how much brakes have evolved until you take the Ducati for a run, and then jump on the other. Savage is a word that come to mind.
The 907's brakes are better with the HEL brakes lines, but still a little to go. It has been having a rest for about 12 months, so all the little rubber bits have dried out. The first time I went out on it after replacing the lines, one of the fork seals started leaking big time. Everything on the LHS is drenched in oil. So that is next, new brake pads and see what happens.
Cheers.
Nick.
PostPosted: Thu Sep 21, 2017 4:46 pm
On mine, I had a couple of scares i.e. lever touching the handlebar trying to stop at a traffic light; at the time I though the issue was with the fluid so I replaced it and after bleeding it several times I decided the MCs where crap and replaced them with the Serie Oro from a 916.
Some purists will say "I ruined the bike's Originality", but I believe it is a mod that could have been made at the time of the bike production, therefore... yes, it is not original, but is not out of place.
With the serie oro the bike brakes as it should, looks nice and feels very nice.
Of course I also replaced the calipers, Serie oro all the way.
PostPosted: Thu Sep 21, 2017 8:24 pm
They look to be the same as the ones on my old SS. I don't think that originality is lost if the mods can be reversed , its not like you had to cut off the old caliper mounts and weld new one on
PostPosted: Fri Sep 22, 2017 4:41 am
PostPosted: Fri Sep 22, 2017 10:33 am
Replaced my clutch w a M695 one.
Bit fiddly w fitting idle lever, otherwise bolt-on.
And original look.
Simpler model ones fr this millenia possible fit.
PostPosted: Sat Sep 23, 2017 3:50 am
New or 2nd hand Nick ? Im pretty sure I still have the clutch side .... and there was no issue fitting it over the choke ( Im assuming that's what Gert means by idle lever ) as the SS had the same handle switch assy as the Paso . Apart from looking a bit more "tech " ( gold , remote rez and adjustable has got to be hard to beat :D ) than the standard ones I couldn't see them making any real difference ..... as long as the overall pump/lever ratios were the same :)
PostPosted: Sat Sep 23, 2017 11:52 am
On a 907, it`s an idle lever, it just lifts the butterfly abit.
It does not restrict air to TB`s.
PostPosted: Sat Sep 23, 2017 6:53 pm
PostPosted: Sun Sep 24, 2017 12:27 am
Hi Hamish.
I found a set of M/C's off a 996. Worth a few Bob, but you get that. After 12 months in storage, they are going back in again for another 3, so all the good ideas will have to wait again.
Cheers.
Nick.
PostPosted: Sun Sep 24, 2017 8:36 am
I stripped mine and got all the brake fluid out and re assembled with brake assy lube . Just reasoning that moisture would get into any residual fluid and cause corrosion
