It is currently Sat Mar 07, 2026 1:50 pm
[ 6 posts ] |
| Author |
raicerx
Post subject: SMOKING TAILPIPE AT STOP LIGHT Posted: Mon Sep 25, 2017 5:31 am |
Joined: Thu Mar 20, 2014 11:51 pm Posts: 8 Location: USA
My 907 randomly blows large amounts of exhaust smoke at stoplights. Doesn't seam to follow any pattern. Just random blow of oil smoke. Not coolant , definitely smells and looks like oil. So what is allowing oil to enter the combustion chamber at stops after both low and high speed runs?
| Top |
Post subject: Re: SMOKING TAILPIPE AT STOP LIGHT Posted: Mon Sep 25, 2017 5:51 am |
| paso grand pooh-bah |
worn guides,worn or missing seals,crankcase breather issues, too much oil improper valve lash
or any combination of all of the above
Could even be as simple as the wrong oil
| Top |
Post subject: Re: SMOKING TAILPIPE AT STOP LIGHT Posted: Mon Sep 25, 2017 9:12 pm |
Or even might be burning oil all the time and you only get to see it at a standstill. Does it use much oil , what do the plugs look like ..... both the same or is one oiled up ( don't mix them up as you remove them ..... )
| Top |
raicerx
Post subject: Re: SMOKING TAILPIPE AT STOP LIGHT Posted: Sat Feb 17, 2018 1:46 am |
It blows tons of smoke when I come to a stop, it isn't a constant smoke thing. It reminds me of my high school car '74 camaro that smoked like a military grade smoke grenade at random moments. it turned out to be the trans breather thing. How do I check the oil breather valve?
| Top |
Post subject: Re: SMOKING TAILPIPE AT STOP LIGHT Posted: Sat Feb 17, 2018 10:43 pm |
Don't spose you have had the valve clearances done just before this started ?
| Top |
raicerx
Post subject: Re: SMOKING TAILPIPE AT STOP LIGHT Posted: Mon Apr 23, 2018 1:58 pm |
No resetting of the valves recently. Had complete valve work done less than 2k miles ago. The bike doesn’t smoke at all except for a random event once every 20 minutes or so at speed and idle. No seaming reason. I’m thinking the breather.
| Top |
[ 6 posts ] |
Users browsing this forum: No registered users and 13 guests |
