It is currently Wed Feb 25, 2026 3:18 pm
[ 3 posts ] |
| Author |
1989750Sport
Post subject: I want to switch to a 17 inch rear wheel, where do I start Posted: Sat Nov 04, 2017 11:33 pm |
Joined: Thu Nov 02, 2017 12:16 am Posts: 50 Location: UK
Hi all, Saw a couple of threads about using a rear wheel with a 17mm axle. 1. So I've located a wheel and he's verifying the axle size.
What model and years shoul I look for? 1990 907ie ... any others?
2. It has a tyre; a 160-17
3. Disc is included so I'm looking for a rear brake bracket to match?
4. That leaves me in need do a spacer. Was going to bore some zinc washers and glue them together until I got the spacing right. Then have a permanent spacer machined.
Seems realatively cut and dry, but I tend to put the ass in assume, so what am I missing?
| Top |
whitepaso
Post subject: Re: I want to switch to a 17 inch rear wheel, where do I sta Posted: Wed Nov 08, 2017 5:40 pm |
Joined: Sun Feb 19, 2006 12:00 am Posts: 143 Location: Bolivar, Ohio USA
I would start by buying a new correct 16 inch tire size from Shinko - they are available now if you were not aware of that. Not sure of your motivation to go to 17 inch rear but considering the conversion/fabrication headaches you will have to contend with, I would avoid. The issues I know of are frame geometry weirdness, swingarm/tire clearance issues, chain/tire clearance issues, wheel/direction of rotation centering, custom spacers, custom brackets, etc, etc.
Many members here have had success but that was before new tires became available. That is no longer an issue though.
| Top |
Post subject: Re: I want to switch to a 17 inch rear wheel, where do I sta Posted: Wed Nov 08, 2017 8:30 pm |
| paso grand pooh-bah |
ground hog day ?
| Top |
[ 3 posts ] |
Users browsing this forum: No registered users and 2 guests |
