It is currently Sun Mar 01, 2026 12:30 pm
Post new topic Reply to topic  [ 509 posts ]  Go to page Previous  1 ... 11, 12, 13, 14, 15, 16, 17 ... 34  Next
PostPosted: Sat Dec 23, 2017 5:54 pm
I would try drilling it right thru with a small drill ( 2-3mm ) and maybe bigger .I have found that with these things and broken bolts/studs that drilling them thru can loosen them a bit . Don't drill to big as you still need some metal for the drift to bear on. You could drill a 5-6mm hole and thread it , then using a few 8mm washers as a spacer on the end of the shaft , thread the bolt in and pull it out...........or maybe a slide hammer
PostPosted: Sun Dec 24, 2017 1:07 am
Thanks for replays, I figured I needed to grease for internal of spacer with the oring over the shaft and for clutch drum over shaft, first pic is where I thought to drift the piece back out the way it came, second is where it's at now , I'm going to see if I can get a strong magnet to fit inside shaft and pull it out , I tried a nice new little drill bit on the broken guide but she didn't want to drill at all, don't suppose anyone can tell me if I am trying to drift from the right place,ie the hole in the centre of the first pic
PostPosted: Sun Dec 24, 2017 1:31 am
Some reason I can't upload pics right now, but I think the drift hole is behind the little cover with 3 bolts in it just forward of the primary cog
PostPosted: Sun Dec 24, 2017 9:08 am
PostPosted: Sun Dec 24, 2017 11:18 am
Here's the pics , I tried really strong magnets but the stick welder got the broken piece out, I lined the start of the internal of shaft with a little every paper to resist spatters there, the thing is whatever's I'm the alternator side doesn't want to go any further and clutch side seems the same with a blockage further in, and that's a very pretty engine build mate, merry Xmas guys
PostPosted: Sun Dec 24, 2017 11:19 am
Yeah got the pics round the wrong way
PostPosted: Sun Dec 24, 2017 12:16 pm
that engine is from a german 907IE owner who's also on this forum. Here's more info about it:
https://translate.google.com/translate? ... motor.html
(Google translation)
PostPosted: Mon Dec 25, 2017 10:44 pm
PostPosted: Tue Dec 26, 2017 2:10 pm
I did wonder if the hole went right through on earlier bikes. G's idea is good.
PostPosted: Wed Dec 27, 2017 2:35 am
Thanks all I got the broken guide out so I reckon I'm all good to go , thanks all
PostPosted: Wed Dec 27, 2017 9:15 am
I assume this picture was taken with the pin still inside?
PostPosted: Wed Jan 10, 2018 12:09 pm
That blockage is still there after removing my trouble broken guide, is still have a clear run of 50_60mm inside the shaft, so new guide/ control plate should be ok , I hope :) now a trial run with the new clutch plates, springs,clutch nut fastened and old control plate in place, my concern is will that outside steel plate be a problem being a little proud of the clutch drum,probably other things to look out for too , just stumbling through at the moment , out of the kit I have 2 drive plates and 2 friction plates left out, I have read faqs still confused , help and ideas always appreciated
PostPosted: Wed Jan 10, 2018 12:11 pm
PostPosted: Wed Jan 10, 2018 12:23 pm
PostPosted: Thu Jan 11, 2018 12:22 pm
Trying to load a better pic of Barnett instructions where I have circled the omitted plates otherwise I have followed the instructions
